586,094 active members*
4,017 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Question about setting X Y part origins
    Apr 2015
    26
    When I first started working with Fadals at my present job, I was shown a quick way to set a part origin (That they would use for engraving) by typing "SETX" enter, "SETY" enter, and "SL,1" enter (for Set Length, Tool #1) with the tool at the desired location.
    The more "normal" way to me, is going to "Utility", "Fixture Offset Setting", selecting a work offset ("1", or G54; "2", or G55, etc.), and zeroing X and Y at the present location. And then, using the tool setting cycle for tool length (and diameter) offsets.
    At the end of the day, I always park the axes in the Cold Start position to be ready for the next morning. I've noticed that when asked the question, “Do you want to move to the last home position?", If I respond "No", my origin will be lost if I used the "SETX" "SETY" method (With "Yes", it is preserved.). As I would expect, an answer to this question either way does not affect my G54/G55, etc. setting, when I use that.
    Where, or in what way, is the "SETX" "SETY" stored in the machine? It doesn't show up under any of the G5_ locations in the fixture offset table, that I have seen. And the fact that it is affected by the home position question... The method of setting the tool with "SL,_" does show up in the tool offset table and can be modified there, as I would expect.
    Re: Question about setting X Y part origins
    SET(axis) or SETH establishes the tooling coordinate system home. it is not an offset but rather a coordination system. SETCS returns to the MCS cold start position.
    Apr 2015
    26
    Ahh - Thank you.
  1. Replies: 4
    Last Post: 11-02-2018, 11:19 AM
  2. Question about setting Z zero in part/fixture origin (G54, etc.)
    By mwbridgwater in forum G-Code Programing
    Last Post: 11-01-2018, 03:55 AM
  3. Question on setting up part
    By Jimearsley in forum SprutCAM
    Last Post: 12-30-2015, 12:48 AM
  4. setting part zero question
    By chineshop_guy in forum Tree
    Last Post: 06-22-2012, 04:14 PM
  5. Defining part origins on a 2216?
    By slick_ride in forum Fadal
    Last Post: 01-07-2010, 10:41 PM
