586,112 active members*
3,168 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Is there any reasonably priced 3D scanners for use with a 3 axis machine?
    Apr 2019
    32
    I'd love a 3d scanner that can be used for carving on a 3040 3 axis machine. "3D scanner" brings up a lot but all seem to be scans for 3d printers or 4 axis machines. I imagine the vast majority use 3 axis, but is there any suitable scanners for it? I'm picturing something nut unlike a flatbed scanner but with it moving over the top.
    Re: Is there any reasonably priced 3D scanners for use with a 3 axis machine?
    Well If you want to go cheap, cheap... I have had some success with an xbox 360 Kinect, and software called Kscan3D. There are other options also for software. There is also a cheap scanner called a cyclops that uses a camera and two line lasers. I have about 10 hours invested in it and have never gotten a decent scan.
    If your interested I can help you along a bit.
    Apr 2019
    32
    Thankyou, I never actually knew the Kinect could be used. I have one for the xbox one laying about somewhere so I will definitely look into the PC adapter and giving it a go. I had seen the Ciclops but it looked like it scanned at such a low angle that it wouldn't be well suited to the task. I also sent a request off to a pro service so waiting to hear back from them, its only a small job, a knife handle but I've no idea what they want for something like this.
    Apr 2003
    540
    I found a Kinect cheap ($10) on craigslist and used it as mentioned for some 3d printer stuff. Worked very well. Never tried it for CNC router objects. You can produce some pretty good 2 1/2D objects for reliefs/carvings with Vectric or Artcam software just by using high contrast black and white photos or adding gradients to shapes/drawings using photo or drawing software. Seems that would work well for producing 2 sides of a knife handle. There are plenty of tutorials on the web explaining how to do so.
  1. 3D Scanners ????
    By maddbomber in forum Uncategorised CAM Discussion
    Last Post: 12-26-2020, 01:15 AM
  2. OBD2 Scanners
    By sotan in forum Other Manufacturing Processes
    Last Post: 02-18-2019, 02:11 PM
  3. Looking for a reasonable priced 4th axis for my machine...
    By airbrush in forum DIY CNC Router Table Machines
    Last Post: 01-05-2017, 10:04 PM
  4. Scanners and Mach 3
    By monte55 in forum Mach Software (ArtSoft software)
    Last Post: 11-19-2006, 05:30 PM
  5. resonably priced 3 axis cad/cam for a lathe????
    By theemudracer in forum Uncategorised CAM Discussion
    Last Post: 07-21-2006, 07:39 AM
