586,043 active members*
3,574 visitors online*
IndustryArena Forum > Tools / Tooling Technology > Metalworking- / Woodworking Tooling / Manual Machining > Can anyone recommend a tool for shaping cricket bats from English Willow?
    Feb 2019
    14
    Trying to get an easier to work with finish on a cricket bat design. Just not sure if I should be using a bull nose or flat or what sort of bit to get the best results. Anything rounded seems to leave too much in the way of grooves to smooth out. Have also tried horizontal movement but the cuts seem to add additional problems with the spine.
    Attached Thumbnails Attached Thumbnails 79270630-6550-4FB4-966E-F93AE194CA25.jpg   B31B69BD-635C-4AEA-99AE-555A99A9E542.jpg   DC672B69-F526-483E-9C18-1866473607D8.jpg
    Jul 2018
    6339
    Re: Can anyone recommend a tool for shaping cricket bats from English Willow?
    Hi X17 - If you have a 3 axis machine definitely not a flat bottom tool. I make hydrofoils and use a 1/2" round tool. A veining router bit with a 1.0 - 0.5mm stepover and that cleans up very easily. Peter
    Apr 2004
    5737
    Use as large a ball-nose cutter as will fit in the spindle. If the cusps between passes are too large, space the passes closer together. Cut lengthwise, with the grain.
    Andrew Werby
    Website
    Feb 2019
    14
    Thanks guys! Will have a test of both solutions
  1. Need cricket bats$$
    By Dazza0101 in forum Australia, New Zealand Club House
    Last Post: 11-13-2017, 04:16 AM
  2. please, recommend a tool grinding machine
    By deadlykitten in forum Toolgrinding / Toolgrinding Machines
    Last Post: 11-28-2016, 03:27 PM
  3. Please recommend a parting tool
    By mike82 in forum Mini Lathe
    Last Post: 01-16-2013, 08:14 AM
  4. Fabrication Shop in Willow Grove PA is Hiring Helpers
    By ToddDavid in forum Employment Opportunity
    Last Post: 09-18-2009, 04:32 PM
