Hi all .,
Since i know that Galaad can be used for Isel / Techno Isel i am hoping i have come to the right place..
I have buildt myself a cnc machine " workbee 1500*1500 " with acme ball screws.
Im using Nema 23 57BYGH 23HS9430 Stepper Motors and DM542A drivers , 2 psu´s 36v 9Amp "one for 2 steppers" so getting 4.5Amp to each stepper ,,, 24v 5amp psu for the Axemotion Pulsar Board
I have the Axemotion Pulsar board and galaad / kay for control
Im having problems with the movements , i have set all 4 drivers to 3200 steps , have sat the pitch to 8mm as suppose to , all axis to 3200 steps and using coupled Y axis..
Now my problem is that when i run the X axis i get perfectly smooth movement and the right travel distance.
BUT ., when i try to run the Y or Z axis im getting a travel distance of 40mm instead of 10mm , and if i try to run with feedspeed above 30mm/s the Y axis will stall randomly on right or left stepper and the gantry gets skewed..
Im not getting stalls on the Z axis but not getting right travel distance..
I have been using kay as a controller for about a year now with an old isel machine and not really had any problems... so wondering if im doing something wrong here..
Another issue im having is to try and run with a slave axis instead , cause no matter what i try i never get any movement on the stepper..
I tried all settings i can for 4th and 5th axis... as independent axis , lathe , Y X Z slave but i can never move the stepper one bit in manual control.. i know its setup correctly with wiring as it works as a coupled axis... and the X works perfectly and everything is wired in the same way in my box..
So there must be something im doing wrong with the parameters in galaad that im just not seeing...
So im really there are some " nerds " with enourmous brains that can help me out
If anyone needs pictures ., please just tell me what u need pictures of and ill post them..
Best regards ,
Kristjan
Ps: im posting almost the same post in woodworking forum also..
