586,390 active members*
2,923 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Stepcraft > Can I use a 220/110v pwr converter to enable use in both Hungary and USA? SCraft D600
    Hello all,
    I want to start with the fact that my electrical knowledge is quite basic. We will be purchasing a Stepcraft D600 to use in both USA and Hungary. They let me know that I would need to be two of each electrical component because the wiring for 220 vs 110 is different.
    I am hoping instead of buying multiples of each electrical component (spindle / laser module / remote switch box / etc) we could purchase a 220/110v power converter. Something like this perhaps?
    [url]https://www.amazon.com/dp/B07MP1NVH1/ref=sspa_dk_detail_2?psc=1&pd_rd_i=B07MP1NVH1&pd_rd_w=EfivF&pf_rd_p=45a72588-80f7-4414-9851-786f6c16d42b&pd_rd_wg=CICYc&pf_rd_r=MDZC94PCEVBJT1JMP7MS&pd_rd_r=00ffb284-9599-47bf-ac47-975e62545e0e&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFNOVAxMEFPRllCMjQmZW5jcnlwdGVkSWQ9QTA2MzkxNTZCOFZFMFNEUUwxQlMmZW5jcnlwdGVkQWRJZD1BMDY1NjcxNDNRSkJYRTc2MkJZQkomd2lkZ2V0TmFtZT1zcF9kZXRhaWwmYWN0aW9uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl[/url]
    Thank you!,
    Nathan
    15362
    Re: Can I use a 220/110v pwr converter to enable use in both Hungary and USA? SCraft
    [QUOTE=Nathan_KCAI;2324866]Hello all,
    Thank you!,
    Nathan[/QUOTE]
    Yes that would work if you have enough amperage output for your machines
    Mactec54
  1. VFD 110V-110V parameters setting
    By Gautier in forum CNC Machine Related Electronics
    Last Post: 11-12-2021, 05:17 PM
  2. Laser Cutting machine manufacturer in or near Hungary
    By hkcj in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-13-2018, 06:26 AM
  3. Coherent D600 Powersupply Pin-out
    By stupidusername in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 12-08-2015, 08:04 PM
  4. Zero machine Tour WABECO D600
    By Henri29 in forum French
    Last Post: 03-29-2013, 01:23 PM
  5. Hi from Hungary
    By Leosoft in forum European Club House
    Last Post: 06-22-2009, 09:34 PM
