586,058 active members*
4,086 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Converting Momus CNC machine to ball screw.
    Jul 2007
    36
    I am thinking of converting my momus to ball screw because timing belt design seems to have been unreliable dropping steps somewhere . Have been unable to zero in on exact problem but on a task involving the making of small wooden crosses every now and again the main leg had a taper instead of being parallel.
    So question is can i change to use ballscrews.
    My Steppers are Keeling Hybrid KL23H284-35-4bs and the driver is a Gecko 540 .
    I am thinking 16mm ball screws from china.
    TWO on X axis (800mm long) one either side the carriage attached to the the gantry. The Y axis at 600mm another 16mm ballscrew.
    As a basis is this a good approach.
    The z already has a thread/block feed set up.
    many thanks
    Raynor J
    Jul 2018
    6339
    Re: Converting Momus CNC machine to ball screw.
    Hello Raynor - Belts should not slip and motors should not loss steps.. You need to look at the Momus mechanics and figure out the issue. Ball screws are good but the current system should be reliable. Is it 10mm belt? My belt drive will only miss steps if it crashes. My system uses the G540 as well. I just looked at the Momus site and does your machine only drive on one side? If so upgrade to drive both sides, I expect that's the issue...Peter
  1. Converting Momus CNC machine to ball screw.
    By raynorj in forum Linear and Rotary Motion
    Last Post: 10-02-2019, 08:55 AM
  2. Conversion of Momus to ball screw for X and Y
    By raynorj in forum Momus Design CNC plans
    Last Post: 05-12-2019, 09:09 PM
  3. Machine Build ball screw mount question
    By chevydyl in forum Linear and Rotary Motion
    Last Post: 10-27-2014, 03:07 AM
  4. Will the ball screw run a big machine??
    By Holchr in forum Uncategorised MetalWorking Machines
    Last Post: 05-29-2013, 08:22 PM
