586,685 active members*
2,716 visitors online*
Results 1 to 7 of 7
    Oct 2019
    CW-3000 Chiller beeping
    I have been using my CO2 laser machine for about 4 years, almost problem free. the chiller has never alarmed until last week. i thought it was hot, but after digging into it, it was alarming at 20 C. I read some posts, and watched a few videos to trouble shoot. What i know so far is there is plenty of water in it, the pump is circulating water, and it still alarms with the cover off. upon start up it will do its beep like it always does, then it's quiet for about 20 seconds, then it will alarm constant.
    If anyone has info on what's going on, or has had the same problem i would appreciate it. Thank you!
    Sep 2005
    1740
    Re: CW-3000 Chiller beeping
    Is it alarming because of low or no water flow or because it not cooling, which means the compressor is not running. This is the refrigerated model…. correct? Turn off, grab a 5 gal clean bucket and pull a hose off the back of the laser, the OUT one if they are marked. Water should run out the machine connection, and when you turn the pump back on it should pump water out of the machine, if not thats your problem.put that hose back on and try to see if the IN hose is pumping. I have had algae plug up the laser tube hoses and cut off the water flow.
    Jan 2008
    940
    There is no compressor in a CW3000
    Nov 2008
    643
    Manual says water blocked or water shortage or faulty pump.
    Oct 2019
    37
    Quote Originally Posted by Tsassen View Post
    Hello,
    have you try to replace a water chiller?as the chiller cost very low.
    James
    Apr 2017
    4
    We run a pond algae killer in our chiller as well we use water that has gone through a reverse osmosis process so it has pulled out all the minerals out of the water. haven't had a algae build up since and that was 3 years ago.
    Nov 2019
    7
    Perhaps a sensor went bad....
  1. Cw-3000 Chiller enough for 80W Machine?
    By tt_bala in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-01-2018, 09:13 AM
  2. Water Chiller CW-3000 ....Beeping
    By cdesigns in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-23-2016, 10:50 PM
  3. CW 3000 Chiller Alarm Wont Stop, need some help please
    By jmstapp8 in forum USA Club House
    Last Post: 08-24-2015, 03:20 PM
  4. Beeping VF-2
    By MDISolutions in forum Haas Mills
    Last Post: 08-18-2011, 10:35 PM
  5. Beeping X4
    By Edwinrist in forum Syil Products
    Last Post: 08-06-2010, 02:16 AM
