Re: Size for ground wires
Originally Posted by
millhouse_
Ok. Thanks. Another question:
As you can see on the picture the panel has three line-in wires. Each one with hot/neutral/ground.
I would like to crimp their grounds together and use them like one large ground wire. Is this a problem?
One example is DIN rail mount terminals, you can get them with automatic ground to the enclosure, they are half green, half yellow, and are intended for such cables that also include a ground conductor.
The ground in this instance is through enclosure bonding, but also pays to take a single correctly sized one to the star point also.
This is the method I have used for over 50yrs.
Al.
Albert E.
