587,012 active members*
3,366 visitors online*
Page 1 of 3 123
Results 1 to 20 of 42
    Mar 2018
    71
    Size for ground wires
    at the moment I'm building the control panel and could need a little help with the size of the ground wires.
    The source wire is 1,5mm^2. All consumers are internal connected to a star point. Would it be a problem if the consumers ground wires to the star point are thicker (2,5mm^2) than the input source ground wire or is it necessary that the wires to the star point are smaller than the source wire?
    Here are some pictures: (In the future all ground wires will go to ground temrinal blocks on a rail..)
    107
    Re: Size for ground wires
    Never smaller .Larger ok.
    Mar 2018
    71
    Ok. Thanks. Another question:
    As you can see on the picture the panel has three line-in wires. Each one with hot/neutral/ground.
    I would like to crimp their grounds together and use them like one large ground wire. Is this a problem?
    24223
    The Ground wire should be the same gauge as the supply conductor or same as the combined size, if supply is from difference sources.
    All ground wires should terminate at the star point or be joined and continued with a single conductor equal to the combined gauges.
    The service ground should also terminate at the Star Point GND.
    There was a copy of NFPA79 out there if needing guidance on regs for enclosure wiring.
    Al.
    Albert E.
    15362
    Quote Originally Posted by millhouse_ View Post
    This is a good question, so if other devices require or have a larger Ground wire, this could indicate that your main supply is to small 1.5mm is only 15 Gauge ( close enough to 16 Gauge ) most cabinet's need at least a 30A supply which would be 10 Gauge, so I would say you input supply is a little on the light side
    What size is the VFD Drive ??? this will need a Power Filter on it input supply
    The Mains Power Supply Ground Connects at the Star Point
    Mactec54
    15362
    That is not a good Idea, how can you have 3 Main Power Supplies from 3 different power outlets, you should only have ( 1 ) for your whole cabinet
    Mactec54
    Mar 2018
    71
    Thanks for the feedback.
    The first power input is for the 5v and 12v power supplies and maybe for other stuff in the future like a vacuum cleaner etc. And it is connected to a contactor that switches on the other two inputs ( one for the steppers and one for the spindle ). Normally I would have used 3-phase current for this but I don't have the possibilities for this.
    @mactec54
    The consumers don't need 2,5mm^2. I just used it for them.
    Sep 2005
    1740
    We routinely build control panels for production lines with multiple power sources and grounds. They are all sourced from the building main 13.8 Kv and substations. All grounds are tied back to the main substation. It makes no difference. Your control panel needs a disconnect for each source.
    15362
    @mactec54
    Ok what size is the Spindle Motor and VFD Drive how many Kw and Amps
    Mactec54
    15362
    Quote Originally Posted by wmgeorge View Post
    "Routinely build control panels" the last control box you used I recall you brought it already made for your hobby machine
    Mactec54
    24223
    One example is DIN rail mount terminals, you can get them with automatic ground to the enclosure, they are half green, half yellow, and are intended for such cables that also include a ground conductor.
    The ground in this instance is through enclosure bonding, but also pays to take a single correctly sized one to the star point also.
    This is the method I have used for over 50yrs.
    Al.
    Albert E.
    Sep 2005
    1740
    Before I retired and started drawing the bucks for not working… just being a hobby guy. Yes even my hobby panels are wired to Code. We wired some pretty good sized industrial plants.
    Looks like Al and I did the same work.
    24223
    Could be.
    Mostly retro fits, PLC control panels and CNC retro fits with Fanuc and Mitsubishi, designed a few custom ones with Galil motion cards, which are a pleasure to use.
    Al.
    Albert E.
    Sep 2005
    1740
    Could be.
    Al.
    Not the same. I installed and wired production lines, moved old junk machines at times into the modern world. Plus new stuff also, some PLCs. some solid state control systems as prototypes and just a lot of MCC wiring to machines and tying in interlocks and the like. At the time I was working under a very strict Master Electrician. Later on I was the sole electrician for second shift production. Loved every minute of my electrical work. Later got into Commercial HVAC/R work specialized in controls.
    Mar 2018
    71
    This is it now:
    Mar 2018
    71
    @mactec54
    It is a basic setup. 4x High torque Nema-23 Stepper, 2.2kw Spindle
    But I want to upgrade later and don't want more than 10A per line-in.
    15362
    @mactec54
    2.2Kw Spindle you are not going to run it on a 10A circuit even a 20A circuit won't run it without problems, the minimum circuit to run a 2.2Kw spindle is 25A at 230v
    Mactec54
    24223
    This is it now:
    I see you are already using the DIN rail GND terminals!
    Some cable trough would have neaten'd it up a little!
    Max.
    Albert E.
    Mar 2018
    71
    @mactec54
    As far as I know those 2.2kw + VFD sets won't exceed 8A.
    Mar 2018
    71
    @al_the_man
    Just added them yesterday to replace the messy wiring with the enclosures ground pin. Not a beauty but it's still a work in progress.
Page 1 of 3 123
  1. Stepper motor wires size, possible step loss?
    By QinX in forum Stepper Motors / Drives
    Last Post: 03-24-2017, 05:39 PM
  2. help with wires
    By linkintiger in forum DIY CNC Router Table Machines
    Last Post: 02-25-2011, 04:00 AM
  3. Frame ground vs. Electrical ground.
    By polaraligned in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-24-2008, 11:21 PM
  4. To Ground or not to Ground That is the question!
    By Mr.Chips in forum DIY CNC Router Table Machines
    Last Post: 03-16-2008, 09:10 PM
  5. Motor supply ground vs Logic ground?
    By Gashmore in forum CNC Machine Related Electronics
    Last Post: 06-07-2005, 11:21 PM
