586,033 active members*
3,627 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > DNC Problems and Solutions > Help, Artisan IFB Card 37 Pin to LP 25 Pin Adapter
    Feb 2006
    62
    I am looking to see if anyone has made an adapter cable for sale, that takes the 37 pinout from an IFB Card (Artisan software interface card) to a standard 25 pinout. I need this interface cable so that I can use a Griffin Controller directly to an LPT port on a PC, thus for use with Mach3 software.
    Artisan software typically uses the IFB card interface plugged on a spare port of the PC mother board. I am trying to do without it, and go directly from controller to the PC using the more modern Mach3 control software. The thing is that the Griffin controller is wired for a 37 pin connector to match the IFB card, it has separate aux and Limit SW Sub-D connectors that branch from the 37Pin connector, so I just need the interface 37 to 25 pin cable since all the pinoputs stem from the 37pin connector.
    I can make one but it would save me the hassle if someone already has one for sale at a reasonable price.
    Thanks IA
    Feb 2006
    62
    Ok, I looked at options and found some breakout boards, might be an option or simply install a 25 Pin male connector on the existing control box and rewire the 4 IMS Drives directly to the 25 connector? I don't think I need optoisolation because I think the IMS drives in the Grifin Control box, already have it inside them. But I have yet to verify this with IMS specs..looking some more... Any suggestions comments, options would be appreciated?
    Feb 2006
    62
    no comments or suggestion? so far...
    Apr 2007
    46
    Feb 2006
    62
    PR ,I cannot acces that group until I sing in and they approve me. So would it be posible for you to copy and paste that info here in this thread? Thanks
  1. 1/4 to 1/8 collet adapter?
    By CRFultz in forum DIY CNC Router Table Machines
    Last Post: 04-17-2010, 07:54 AM
  2. need help with lathe adapter
    By Lionclaw in forum MetalWork Discussion
    Last Post: 01-03-2007, 02:02 PM
  3. 56c motor adapter for IH
    By Runner4404spd in forum Charter Oak Automation Support Forum
    Last Post: 10-28-2006, 05:02 PM
  4. 3/8 to 1/2 adapter
    By TMaster in forum Benchtop Machines
    Last Post: 07-29-2006, 12:15 PM
  5. Adapter for ballscrew
    By ahren in forum DIY CNC Router Table Machines
    Last Post: 03-24-2006, 12:51 AM
