586,069 active members*
3,387 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Adjust bearings in BK style mount?
    Jan 2011
    30
    I have a pair of used BK mounts. One of them fits tightly on a screw but the other one has a "wobble" when mounted on the same screw. I am assuming that the angular contact bearings in the wobbly one are either worn or the tension needs to be adjusted. The screws have been marked with paint marker. Is the tension entirely adjusted with these external screws or are there internal adjustments? I'm very tempted to take it apart. Any suggestions about how to fix this?
    Attachment 428710
    Nov 2013
    4373
    Re: Adjust bearings in BK style mount?
    my understanding is that angular contact bearings for such purposes are sold as a matched pair. They are ground
    in such a manner that when the outer annular rings are clamped the inners are under the right preload.
    A regular angular contact bearing say a 7204 (20mm ID) might be $20, a matched pair of P4 grade 7204's for CNC
    machines could be $200 or more.
    That your bearing pair has a 'wobble' suggests to me that the ball separator has failed in one or both bearings. You will
    have to disassemble them to find out. Should you ever wish to reassemble them you MUST mark every pieces orientation
    as you disassemble otherwise all semblance of matched precision is lost.
    Depending on your budget and how hard and fast you want to operate these bearings you could try a couple of angular contact
    bearings and rely on 'random matching'. If you assemble them 'with a fitters magic feel' you'll probably get away with it, at least
    for non-demanding applications. Other than that you are up for a matched pair......and if you think $200 a set sounds bad spare
    a thought for specialist machine makers who use high angle of contact bearings especially for axial thrust capability and all
    ceramic at over $1000 a pair!!!
    Craig
    Jun 2007
    3891
    Nah. the bearings they put in these smaller blocks are $50-$100 per matched pair at misumi. P5 grade is all you need general (radial runout is not very important, nor is high speed). The expensive stuff its spindle bearings, which are not even vaguely similar to ball screw support bearings in geometry or spec.
    If thats a higher end block from thk or nsk, the bearing pair will likely be pinned together and not seperable or adjustable in any way. Cheaper blocks may have 2 separate bearings.
    Note that the bearings are meant to "wobble" to a degree. They are oriented face to face so they can tolerate shaft misalignment. So wobble alone does not indicate anything. You need to measure axial movement.
  1. Is there a proper way to mount fk type ballscrew bearings?
    By blitz355 in forum Linear and Rotary Motion
    Last Post: 10-01-2015, 10:21 AM
  2. How to mount thrust bearings
    By Spitfire in forum Linear and Rotary Motion
    Last Post: 07-17-2015, 05:42 PM
  3. How to mount bearings?
    By jimluu in forum Linear and Rotary Motion
    Last Post: 01-04-2008, 03:54 PM
  4. Any U.S. Source for this style of bearings and channel
    By gloomsayer in forum DIY CNC Router Table Machines
    Last Post: 01-07-2006, 05:44 PM
  5. How to mount Bishop Wisecarver bearings.
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 09-20-2005, 09:28 AM
