586,604 active members*
3,600 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > How to show Rpm instead of frequency? FVD yl620-a
Page 2 of 2 12
Results 21 to 26 of 26
  1. #21
    15362
    Re: How to show Rpm instead of frequency? FVD yl620-a
    Quote Originally Posted by Cosimino71 View Post
    Since you are very kind and prepared I would like to ask you how to install a diode laser that I had on my cnc 3018, I would like to put it on my new cnc with mach3 system the spindle I command it with the Vfd panel but I would like to control the laser from the system but I don't know what I need.The 15w laser has three wires and is equipped with ttl that you can control with pwm I am sending you the photo of the controller attached
    I don't know how you want to control your laser, but I see your breakout board has a PWM output which may work for your laser, to use the PWM output you would control that output like an Axis as it can be an axis Step / Dir or a PWM output you may have to change a jumper on the board if it has one so it would be P1 and PC GND for the PWM output failing to get this to work you would need to add a PWM Board
    Mactec54
  2. #22
    Sep 2020
    11
    my laser has three wires a positive a negative is a yellow wire which should be the ttl signal it worked in pwm without any additional card because it has its own, on the 3018 card it had a specific input for the laser another cable in the box that I have never used I send you the photos so you can see and give me directions for connecting to my breakout board
  3. #23
    15362
    You would have to test that 5th axis port to see what it can do it has the PWM and Gnd just have to test it and see which pins you can use, and if it can give you the output you need, I have never connected a laser up to a board like this so just testing is your best way to find out if it can fire your laser
    Mactec54
  4. #24
    Mar 2022
    I know this is an old thread, but in case someone else is searching for this. To show rpm on your inverter you have to set P00.24 to 9 and P00.23 to 60%. That will show your speed as (at 400Hz) 'u2400'. Or if you set to 6% is will say 'u 240'.
    Yes, it doesn't show the 24000 rpm but it is better than nothing!
  5. #25
    15362
    Quote Originally Posted by Wiseman1 View Post
    Thats good information but you have to say what make and model number VFD Drive this is for, they are all different.
    Mactec54
  6. #26
    Thanks, that worked
Page 2 of 2 12
  1. YL620-A VFD setting question.
    By regpye in forum Spindles / VFD
    Last Post: 03-25-2021, 12:44 PM
  2. Vfd YL620-a initial setup
    By Terryble24 in forum Spindles / VFD
    Last Post: 12-20-2020, 05:04 PM
  3. Seeking info on proper settings for a YL620-A VFD
    By SpyderHelix in forum Phase Converters
    Last Post: 06-02-2019, 09:22 PM
  4. YL620-A
    By slasher102 in forum Spindles / VFD
    Last Post: 11-06-2018, 07:00 PM
