586,069 active members*
3,743 visitors online*
Page 1 of 3 123
Results 1 to 20 of 43
    May 2007
    22
    BUNOZ-CNC Another Aussie Adventure
    "A CNC what..?", was what my wife said when I told her about some hair-brain idea to build my first machine. Closely followed by "how much!!$#?" and several other expletives.
    Well, it's really not that long ago since I saw my first video of a homebuilt CNC in action. That fateful day set everything in motion I suppose. The mind started churning and the flame of desire for one of these computerized marvels went from a small pilot light to a roaring inferno the more I read and researched.
    So the decision was cast, a machine had to be built, but it had to be done on a fairly tight budget. I looked at a few homebuilt designs that were out there and I was all ready to go with something similar to a Rockcliff design using these fancy linear bearings I've read so much about. (Cough), that was until I got the quote for the bearings
    My CNC dreams came crashing down in a big heap. The cost for the bearings and screws would have cost me close to 2 gorillas and that was before considering motors, controllers and all the other bits which make up one of these monsters. Quite simply, it was just way too much for my first CNC rig.
    Unfortunately in the land of Oz, we don't have the multitude of vendors and suppliers which a lot of you guys can source your components from. So I shelved the whole idea for a while but the concept never left my mind.
    Here in Australia we have a hardware store called Bunnings - its pretty much all there is anymore, but anyhow.. I find myself going there - a lot. Whilst there I ended up with the dream to build a machine using materials which I could source locally (mainly from Bunnings). A design started to take shape in my head and eventually I got to a stage where I had to start putting things together in the computer.
    I know what you're thinking here.. he should have just gone with one of the many designs that are out there. Yes, you're right, but somehow I never seem to do things the easy way. I also set myself a few goals; these were:
    1) I wanted a machine which was large, sturdy and scalable
    2) The machine would need to be a flying gantry type so I wouldn't be constrained by height
    3) The whole thing had to come in at around a $1000 aussie smackaroos
    4) Most, if not all components had to be sourced locally.
    In the spirit of my design goal number 4, I wanted to get my motors and controllers from an Australian supplier. I can't begin to explain the frustration in trying to get the right information and bits at the right price. In the end, I've gone with a plug & play 4-axis system from Xylotex using 425oz. motors. The fact that the AU$ was trading strongly against the greenback and fact that the xylotex system was ready to go straight out of the box had me sold. Have to say I can't regret going down that path. For under AU$700 I had all the electronics and motors, leaving me with around 300 or more to spend at Bunnings on build materials - happy days
    So after much sweat, cursing and tears, I'm happy to say that I've finally finished the design on the computer and can start the build process now.
    I'm sure I'll stuff up a hundred (maybe 101).. times along the way, but I'm starting to enjoy this little project. I'll post pics and stories along the way, but for now, here's a couple of drawings out of the puter.
    If by any chance, you stumble across my sorry tale, look at my design and go "Ach du lieber Gott! What's he doing it like that for.. " and so on and so forth.. then please feel free to comment, contribute or make suggestions at will. I'll take all manner of comments on board and hopefully I'll come out the other end of this whole process with a machine that does .. well .. uhm.. something.
    Here's the main design.
    The main construction is MDF and in critical areas, clad and reinforced with aluminium. The rails are alloy as well with slides that are designed using standard ball bearings and a mechanism to allow for adjustment against alloy inconsistency, build errors and to to pre-load the bearings.
    May 2007
    22
    Day 1
    Today marked the start of the physical build process. No more gazing at the screen it was time to print out some drawings and head into the workshop - yay!
    All bits there and accounted for.. check (well uhm.. at least I think so). Good grief - look at all those bearings..
    I have to say it was good to get started on things and first on the list of things to do was x-axis rail number 1. No real problems so far. The whole thing went together very well and although I took my time with it, I'm sure the others will be a bit quicker as I get used to repeating the process 3 more times.
    So at the end of day one we have:
    - One complete x-axis rail assembly (pic below) and,
    - one of the bearing slide blocks (of which there will be two per rail.
    Tomorrow's task is to build the other x-axis side, make more bearing slides and hopefully complete one of the rail slide assemblies.
    Mar 2006
    427
    Nice progress for day 1. I was wondering what are you using to attach the pipe to your beam?
    Also I noticed that you are using washers to space your bearing away from the angled aluminum. I would suggest just using another nut and not to use any washers because you don't want the washer coming in contact with the sides of the bearing and binding it up. If you have to shim it out even further go nut head, angle aluminum, washer, nut, bearing, nut. Good luck.
    May 2006
    2420
    Hey Denbo, looks like you are off to a flying start !!!
    Great progress so far, it seems you have done a "little" research
    I see in your profile you are in Qld, I don't spose you are further north than Brissie ?... I am waiting for the day we get somebody joining in the fun who is a bit closer to the pointy bit, just south of Cairns myself.
    Welcome to the zone !!!
    Russell.
    May 2007
    22
    Quote Originally Posted by Regnar View Post
    Hi Regnar
    Thanks for your comments. I've posted a couple of pictures below to illustrate how the channels are put together. The illustrations are for my z-axis, but the assemblies are the same throughout. The tube is basically mated to the alloy base by self tapping screws. This is then mated to the other angles using 3mm bolts and then finally secured against the MDF using 16mm screws. The first assembly turned out very solid and the only flex I'm getting is on the rail upright (something that should be sorted when the whole x-axis gets assembled and mated together).
    With regards to the washers, I've made sure that they fit snug around the bolt so there's no chance of them making contact with the outer race. Initially I was going to use a collet for spacing, but the washers I had were a perfect mate so I'll go with that for now and see how things go.
    D.
    May 2007
    22
    Quote Originally Posted by epineh View Post
    Russell.
    Hey Russell
    Nice to see a fellow Qld'er on the board. I'm in Brizvegas - so I'm afraid were just about at opposite ends of the state. Thanks for the welcome though.
    D.
    May 2007
    23
    Another Aussie
    Quote Originally Posted by Denbo View Post
    I understand your frustration about suppliers
    I'm in the process of building a modified JGRO machine
    I was quoted something like $20K for steppers and controller (admitably they said it was for industrial applications not hobby)
    I'm wondering where you got specialized items from (lead screws etc)
    and what did bunnings have to offer.
    I did see the local bunnings had a threaded rod that I was going to have a look at using as a lead screw but I don't think it would be suitable
    May 2007
    22
    Quote Originally Posted by nev25 View Post
    Hi Nev
    The irony is that the industrial and very expensive stuff is probably easier to find than something which is cheap yet usable. The company "Linear Bearings" has ball screws which I was tempted to get. Their rod is close to 200 dollars a meter though and if you want a platform nut you can add about another 400 on top of that. I'm sure the stuff is gold but so is the price.
    Bunnings didn't have the threaded rod I wanted so I got 1 meter lengths from a place called Boltmaster. They are standard M8 rods - straight, cheap and they look fine, but I'm sure they won't be as accurate as ACME or ball screws.
    I want to see what kind of accuracy and reliability I get out of bog standard components before I tear a hole in my wallet for the high precision stuff.
    D.
    Dec 2006
    277
    Good to see another aussie CNC being built and it looks like you have a zylotex kit for the steppers and controller
    Keep up the good work!
    Bob
    May 2007
    22
    Day 4
    I suppose you're wondering where day 2 & 3 went huh?
    Well.. its been slow going. On day 2 I only had about an hour of work on the second x-axis rail before my bandsaw decided to go belly up (Groan!)
    Day 3 was pretty much spent hunting around for a new saw after I decided the old one was overdue for replacement. Spent no time at all on the build of the CNC (bigger groan!). One good thing though was that I got a big chunck of Delrin for 20 bucks from Eplas. The Delrin will be cut into blocks and sit on the screw blocks to move along the threaded rod.
    Ahh.. up to day 4.
    I've managed to finish the 2nd x-axis rail. A quick check - hey would you believe it, they're even level
    Now to the slide assembly. The drawing of this was already posted above, and I approached this with some trepidation as the slide is possibly the most complex bit of the whole design. Lots of drilling, routing and double-checking but I took my time with things and luckily I didn't encounter any major problems. One change I made was to bolt the side angle plates onto the top and bottom slide instead of using screws. The MDF can and will split all too readily. I doubt I'll build in MDF again - would probably use ply if any wood at all.
    Well lets not muck around then, .. here's the bits of the slide assembly coming together and being preloaded against the rail. Whole assembly slides very nicely and had zero play or movement.
    Oooh this is getting exciting now - another slide will have to wait until tomorrow. Once I get that done I can finish the front and back plate of the x-axis and mount the first motors. Lets just hope no more tools break in the meantime.
    Jun 2007
    " 3) The whole thing had to come in at around a $1000 aussie smackaroos"
    Hiya Denbo,
    Looks like a great project on the way there. Masterful use of CAD to make the original designs. Must have driven you crazy at times using Bunnings derived materials - switching from metric to imperial and back
    Just wondering... Has the purchase of 'supplementary' supplies [eg. Beer - Pizza] pushed the project over the top of your original estimate?
    Elwood
    Jan 2007
    16
    Greetings Denbo
    I am really in full agreement with your remarks about obtaining stuff in our "clever country" ! I too wanted a low-cost router/mill that I could cut my teeth on so to speak. I am a newbie, and in my retirement, funds are not limitless. I actually have a Sherline 2000 mill, but do not want to ruin it by my inexperienced efforts. So I thought I should look for ideas in the CNCzone.
    Full marks for your enterprising work, I will be following this thread to lap up the benefit of your experience and progress. Could you please post some dimensions to your drawings, although I can get a rough idea from the pics ? Also when you get to using the Xylotex parts, please post your experience/opinion of that setup.
    Wish you were south of the border though, I'm in Sydney.
    Thanks and more power to your elbow.
    Arvind
    May 2007
    22
    Quote Originally Posted by arvindk View Post
    Greetings Denbo
    Arvind
    Hi Arvind
    The dimensions are 1m rails on the x-axis, 700mm for the Y and 300 for the Z. Basically all made around 1m bits of alloy, which are easy to get and transport. The slide blocks are all 150mm long.
    When I'm done building and got the whole thing running, I'll refine the plans and put up some drawings for people to use if it all turns out being a solid enough machine.
    D.
    May 2007
    22
    Progress..
    After a couple of days of stuffing around and doing little on the CNC, today has been quite productive actually. I finally manged to finish both the uprights for the Y-axis.
    The only drama I've had so far, was that the uprights bolt onto the sliding units of the x-axis via 6 bolts on each side. Unfortunately 2 of those are blind recessed behind an alloy angle which supports the top plate of each slide assembly. This meant that I have to bolt the upright into place before preloading the slide assembly against the rail. Not a huge problem - once you know the sequence of assembly.
    Anyhow, all seems pretty good... everything is still level and square - Amazing!. The only thing left to finish off the whole base is to build the motor/endplate and bolt it all together. The Y and Z axis slide assemblies are modular and should just slot into place on the uprights.
    I managed to try the movement of the x-axis using a cordless drill for the first time tonight. Everything seems sturdy and moves smoothly. This monster sure isn't going to be speed demon. Then again, I kind of knew that one using standard threaded rod. The cost of going to a ball screw is too much at the moment, but I can see already that this will probably be a very real option once I've had this thing up and running for a while.
    May 2007
    22
    On with the show..
    Another generally productive day and I'm happy with progress. Today's achievements were :
    - completed the rear plate for the base, including the bracing
    - mounted both x-axis motors
    - made the motor shaft to threaded rod couplers
    - finished assembly of the x-axis frame
    This marks the end of the battle for the x-axis .. did someone say hoo-ray!?
    Apart from some fighting with the motor mounting bolts and aligning the drive shaft couplings, all else went according to plan. A little fiddly lining everything up square for the base but nothing too serious. It's a bit of a Frankenstein's monster to look at for the moment, but a fresh slap of paint should pretty things up a bit after final assembly. Anyhoo, here is the completed x-axis assembly
    Its all very tight. No slack or movement anywhere and even sliding or turning the whole assembly around isn't mucking with the alignment. About the only thing that worries me is machine vibration and nuts coming loose after time - I suppose, I'll just have to wait and see.
    I also started on the y-rails but the rest can wait until tomorrow.
    The tally so far.. one blunt drill bit, plus 6-million bolts and counting
    May 2006
    1469
    Looking good Denbo :wee:
    Apr 2007
    1955
    Hi Denbo
    Thank you for posting your nice build. I have read quite a few build threads, and I still learn from each one, advantages and challenges.
    If you don't mind, could you tell me a bit about the sizes of parts ?
    - Nominal pipe size ?
    - Approx distance between bearings on the carriage ?
    Metric or English units - does not matter, I am comfortable with either.
    I am really impressed with your ability to hold even close to that budget. I am collecting pricing for a build, and the shopping list so far is way over yours. Maybe I need to re-think my concept.
    May 2007
    22
    Quote Originally Posted by harryn View Post
    Hi Denbo
    Hi Harryn
    The tube is 20mm alloy outside diameter. Carriage size all up is 150mm long by 145mm high. The bearings sit on on 20x20x3mm angle and are only just offset enough from the edge so that the bolt heads don't interfere with each other.
    With regards to the budget, I'm going to go over my AU$1000 estimate, but not by much. The tally at the moment for everything is $1200, which I suppose works out at around US$900. Most, if not all of the materials used, are easy to get and budget conscious. The biggest cost is by far are the motors and controllers. Materials for the build would only constitute around US$300. MDF is cheap, so is alloy. The bearings are standard 8x22, and although there are 36 of them they are again very cheap (under AU$3 ea.)
    If you buy in bulk, like for the bolts and bearings, the cost comes down even more. Good luck with your project..
    D.
    May 2007
    22
    Getting there..
    Time to bridge that yawning gap and put a Y-axis in there he said - heading with confidence into the workshop to kill another day.
    One thing I've now put on the wall in big letters .. after building the Y-rails TWICE... "Always follow the plan!" Here I was, getting a bit overly confident and started drilling holes with spacings pulled out of .. well (uhm) you know where. Turns out that at least 4 bolts were colliding against each other after I got to final assembly :withstupi
    So all got pulled apart again, plans pulled out, holes drilled again .. of course accompanied by much cussing and cursing. After all was said and done though, the Y-axis assembly was hoisted over to the work crane and slowly brought into position. The next stupid thing I discovered was that my beautifully sculpted and curved uprights had to have drill holes in excess of 15cm through the middle of them to mount the y-assembly. Weeelll... I can't begin to describe the joy of having to drill and bolt that sucker into place :tired: . I can certainly see a design change on the cards here.
    Here it is:
    Oh I forgot to mention that with the weight of the y-assembly in place, the rail slides which support it against the x were starting to show the strain and had to be re-tensioned against the rails. This is no lightweight. I'm guessing this thing is up to around 15Kg already.
    What remains? Oh yes, right - a Z-axis. Did someone say toolholder? - sorry, yes, one of those coming up as well. It's sure looking the part though .. isn't it?
    May 2006
    2420
    Sounds like you are having lots of "fun" with your build... if it makes you feel better it certainly looks great.
    It gets heaps better when it starts moving under PC control, you better get ready to have a silly grin for days when that happens
    Russell.
Page 1 of 3 123
  1. Aussie members
    By jbo in forum Australia, New Zealand Club House
    Last Post: 11-25-2020, 06:37 AM
  2. Another Aussie Adventure in Vacuum Clamping
    By Greolt in forum CNC Wood Router Project Log
    Last Post: 05-27-2013, 03:45 AM
  3. LatheMaster 9 X30 CNC Adventure
    By Ron111 in forum Mini Lathe
    Last Post: 10-10-2008, 03:51 PM
  4. Aussie Capacitors
    By epineh in forum CNC Machine Related Electronics
    Last Post: 12-28-2006, 11:58 PM
