586,106 active members*
2,935 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > PRT-E1500W VFD CNC60/90 locked out - cant change VFD settings, flashing 50.00
    Oct 2019
    4
    Smile PRT-E1500W VFD CNC60/90 locked out - cant change VFD settings, flashing 50.00
    Hello!
    I was following a guide for setting up the spindle, and after I set d176 to 1, it seems that it's locked me out or something.
    I can't change anything apart from d176 and d001, and even when I do change those and press the function button, it goes back to flashing 50.00.
    I was able to change the numbers before I set d176 to 1.
    I'm wondering if this has anything to do with the voltage?
    The machine is in the UK, so 220v, I have a feeling that factory defaults changed the voltage to 110v. Now even in manual mode, when I press run, the spindles starts to accelerate and within about 3 seconds it stops and the display outputs E O or E R (can't remember as I'm not with the machine right now). Anyway that's my guess but I really have no idea.
    Would love some help with this, very new to it!
    Thanks a lot.
    Oct 2019
    4
    Re: PRT-E1500W VFD CNC60/90 locked out - cant change VFD settings, flashing 50.00
  1. 6040 cnc PRT-E1500W vfd settings.
    By koolkleptokidd in forum Chinese Machines
    Last Post: 05-04-2021, 04:23 PM
  2. PRT-E1500W 110V VFD SETTINGS for USB CNCEST-6040T
    By mjmurphy99 in forum Chinese Machines
    Last Post: 07-10-2020, 02:46 AM
  3. Haas GR510 tool change locked
    By PD-CNC-GUY in forum Haas Mills
    Last Post: 05-03-2014, 05:11 AM
  4. Siemens 840D controller. Locked in middle of tool change
    By Chuck - Detroit in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-03-2009, 03:31 AM
  5. Replies: 3
    Last Post: 04-01-2009, 11:06 PM
