586,655 active members*
4,197 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > sainsmart 3018 MX3 laser does not immediately honour M3/M5
Results 1 to 1 of 1
    I am using MACH3 with the Sainsmart 3018 MX3,
    The laser does not immediately obey M2 and M5.
    (I'm Using Freecad, which does not issue motor off when G0.
    So I edited the file and added M3/M5 at the correct places.)
    Problem - the laser comes on before the G0's are complete, and
    goes off before the cutting is complete.
    I have added G4 P 2 commands and this fixes the problem, but the
    laser is on for a short time before moving and after stopping.
    Why do I need these delays (using PWM). Can I not turn the laser off/on
    immediately. I also notice the delay when I press "spindle CW F5".
    I saw that I could use M10 or M11 to do this but I cannot set this up.
    I am using USB, and I enclose photos of the board. It is "MACH3 controller for mini CNC" and I have versions 1.3 and 3.1. They look basically the same.
    The DLL that Sainsmart gave me is for BL- UsbMach which when I look it up is for a different board. I am disheatened that I cannot get the laser to sync, but I can a bit if I put G4 commands in. Ienclose my file (G4's commented out)
    Sainsmart say that Drufel (another CNC controller S/W does not have this problem (( conter whick noard - STB5100). But MACH3 is much better.
    Do you have any other driver ideas? I have tried all the settings that I can think of!
    Lawrence
    Attached Files Attached Files
  1. Chinese 3018 cnc from Aliexpress - Laser and Spindle Issue
    By ad_van_ce in forum Chinese Machines
    Last Post: 02-01-2020, 09:31 PM
  2. Replies: 4
    Last Post: 10-17-2019, 08:42 PM
  3. Sainsmart 3018 Pro using Grbl
    By portanav in forum CamSoft Products
    Last Post: 07-30-2019, 04:10 PM
  4. assistamce needed $$ immediately
    By Jwilliamsj in forum SheetCam
    Last Post: 09-29-2014, 03:27 PM
  5. MACHINISTS NEEDED IMMEDIATELY
    By Thermadyne Corp in forum Employment Opportunity
    Last Post: 07-21-2011, 08:52 PM
