586,102 active members*
2,721 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > older Haas drip feed problem
    Oct 2005
    99
    Hello,
    I just bought a 1990 Haas VF1. I am trying to drip feed it, as the memory is very small. All the instructions say to turn on setting 55. Mine stops at setting 54. It is in Yasnac coordinate mode. Will setting that to Fanuc turn on more settings or am I just screwed? I made a rs232 cable and can upload and download programs without issue. Just the memory is too small to do much. Thanks!
    Jun 2014
    8
    Re: older Haas drip feed problem
    hey ron, the yasnak mode if refering to setting 33 is really just how the machine sees the g52. if in fanuc or haas the g52 is applied to all work offsets if in yasnak it turns g52 into just another work offset. it also affects g92 to some degree. as for the rs232 set parameter 57 to 1 after that go into settings type in 55 and then hit the down arrow. depending on the control you might have to turn on setting 7 witch allows you to edit parameters first.
    Jun 2015
    5
    Hello mgutierrez237
    How to edit parameters in yasnac lx3 control.
    MDI mode (as in fanuc)?
    Parameters 6030 to 6049 have been lost.
    I have them on paper.
    Best regards.
ID:	429009Click image for larger version.
ID:	429011Click image for larger version.
ID:	429013Click image for larger version.
  1. Fanuc 0m problem for drip feed
    By Bokikv in forum Milling
    Last Post: 02-16-2018, 04:03 PM
  2. Problem with drip feed!
    By pmanoj in forum Fanuc
    Last Post: 10-14-2016, 01:48 AM
  3. Fanuc OM, Drip feed Problem
    By csgabor90 in forum Fanuc
    Last Post: 06-09-2016, 11:12 PM
  4. meldas 500 drip feed problem
    By Bada Bing in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-08-2016, 08:16 PM
  5. Fanuc Om Drip Feed Problem
    By Stebedeff in forum Fanuc
    Last Post: 11-19-2010, 03:31 AM
