Hello,
I am fairly new to this and have been trying to setup a 40w laser on a greenbull cnc. I'm extremely new to this and was unable to find a lot of good documentation so have been struggling to get this to work for weeks. I have it setup correctly and can get it to test fire with no issue when I press the test button on the power supply and am now working to get it to fire using the cnc usb software. I could not get it to work so I used the test fire button to make sure the laser was still active and accidentally shocked myself.
When this happened I pulled the high tension line loose without realizing it and did a few more test fires over the next 30 minutes with no issue. Then I started seeing the arcing on the video and smelling smoke. I realized the line was not attached to the power supply so I reconnected it and now I can't get the laser to fire at all. Have I ruined the tube or is this something that can be fixed?
As far as I can tell the line is still connected securely to the terminal and I removed the old tape and added some more.
The control board is a mk1 board from buildyourcnc.com
arcing:
https://youtu.be/Oz-KLH1-WZU
laser tube:
https://buildyourcnc.com/item/Laser-...ube-CO2-40Watt
power supply:
https://buildyourcnc.com/item/Laser-...Supply-CO2-40W
I am really struggling with this and would appreciate any help.
