586,060 active members*
4,572 visitors online*
    Feb 2019
    91
    machining acrylic
    Hello just want to ask question regarding edge finishing i already tried many bit most of it same or just a make a little difference from 1 flute hss to 3 flute onsrud carbide all
    here the picture of machine i think it rigid enough to cut acrylic
    using servo motor with 4.5 kw bt30 atc spindle i already test the runout of my spindle its around 0.004mm and im using sk tool holder with 0.002mm runout
    those mark i cant even feel it when i touch only can see it by diff angle mostly i cut w ith 18000 rpm 60ipm
    Re: machining acrylic
    It's most likely due to flex in your machine.
    Feb 2019
    91
    im taking finishing pass with 0.25mm left even with 3mm thickness got this mark is it because of flex?
  1. LD-6000 Acrylic High Light Machining Center
    By longdiaocnc in forum Videos
    Last Post: 11-16-2016, 04:46 AM
  2. Approaching machining plexi and acrylic
    By LaserGuided in forum Glass, Plastic and Stone
    Last Post: 03-27-2014, 10:37 PM
  3. Acrylic cutting issues with non perspex acrylic...
    By amy_stars in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-11-2013, 07:09 PM
  4. Acrylic cutting machining
    By john petre in forum News Announcements
    Last Post: 09-22-2009, 05:39 PM
