586,055 active members*
4,375 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software > Suggestions for Inexpensive Computer(s) for Windows/Mach 3, Fusion and for LinuxCNC?
Results 1 to 9 of 9
    Feb 2005
    54
    Suggestions on inexpensive, but usable computers for running Fusion 360 and for Windows/Mach 3 (I have a license) and maybe also LinuxCNC?
    Minimum config for being usable?
    Oldish garage sale and surplus computers with parallel ports?
    Where does one obtain Windows inexpensively?
    Thanks in advance!
    Jan 2007
    626
    Re: Suggestions for Inexpensive Computer(s) for Windows/Mach 3, Fusion and for LinuxC
    I guess the only possible snag may be in running Fusion.....I'm not sure.
    I good source, to me ,would be second hand Gaming Machines. They would have
    good solid processors, lots of RAM, and a reasonable video card, abeit, a couple of years old.
    Must be dozens on Ebay, or anywhere else people sell gear.Craigslist in the US?
    PC's with parallel ports are rare these days. I would look at getting a Motion Control Card, so you don't need to go that way.
    Aug 2017
    45
    Where I'm you can get as many as you want from craigslist. I bought 6 of them.
    You can install the OS either 32 or 64 bit. If you want to run Mach 3 with a Pport you have to install it 32 bit.
    Running fusion 360 might be possible because it is cloud based so there is not much to install.
    You probably need maximum amount of Ram for fusion 360.
    Sep 2014
    129
    Jan 2018
    1516
    A PC such as this one:
    https://www.ebay.co.uk/itm/Dell-PC-I...EAAOSw4EJcyDyo
    Even a 2.6 core 2 duo would be plenty. 8gb ddr3.
    Then throw one of these old boys in there and you'll be well away.
    https://www.ebay.co.uk/itm/MSI-N460GTX-Cyclone-1GB-DDR5-OC-Graphics-Card-Used-in-excellent-condition/274043943115?hash=item3fce4ab8cb:g:z2wAAOSwfmldbY8 T
    Jan 2018
    1516
    Quote Originally Posted by ScotMarquez View Post
    I also need help choosing a laptop. I work as a writer. I am writing this article for blogs. I need a fast and functional laptop.
    I'd get a refurbished Dell i3/i5 6th Gen.
    I actually bought an older Dell not long ago (i3 3rd gen E5430 under £100gbp) and it is pretty damn good
    Feb 2005
    54
    I bought an old Core 2 Duo, 4GB RAM, 500GB machine with LCD and wireless keyboard and mouse for $10. Has a parallel port on it.
    Suggestions on where to get legit Windows 7 and Windows XP Pro?
    Which would be better for running Mach 3 under?
    I’m keeping my eyes peeled for an inexpensive i5 or i7 machine.
    Is Ethernet SmoothStepper still a good thing for Mach 3? USB SmoothStepper?
    Recommendations on digital step/direction compatible or regular +/-10V AC/brushless servo drives and motors, say 500W-1500W range for axes and 3.5KW for spindle?
    And 4-6 axis, Mach-compatible servo controller recommendations?
    Jan 2018
    1516
    Quote Originally Posted by rpseguin View Post
    Not sure about availability of XP anymore. I luckily have my retail discs from 2005.
    As for Windows 7 I bought a product key from ebay for £5. Downloaded the OS from Microsoft as ISO. Created bootable USB and it all worked fine.
    I couldn't get Mach to work on 7 well enough but it was prob me.
    Be warned though. XP will only work with older machines and will need a SATA controller driver under F6 install.
    There is also issues installing windows 7 on machines post generation 6 processors.
    Windows 10 is being forced (and I hate it) and manufacturers are dropping support.
    I just got a new laptop with a Ryzen 5. There are no drivers available for Win7 and it refuses to install it on the SSD anyway. If I'd known this I would have got a refurbished one from Generation 6.
    Sep 2017
    40
    I use this stick PC running Mach 3 and UC300ETH. https://www.amazon.com/Quantum-Windo...gitaltren0b-20
    I can surf the net run Fusion 360 I simply have it plugged into the HDMI in an old TV with a wireless keyboard. Running windows 10 Home works perfectly.
  1. Single Board computer for LinuxCNC
    By mike944 in forum LinuxCNC (formerly EMC2)
    Last Post: 09-09-2020, 10:24 AM
  2. Post processor for Fusion 360 to Sherline (LinuxCNC)
    By slikmetalfab in forum Autodesk Post Processors
    Last Post: 04-14-2019, 08:09 PM
  3. Computer for Fusion 360
    By medemt in forum Autodesk CAM
    Last Post: 10-01-2018, 05:10 AM
  4. Linuxcnc on Windows Computer?
    By CATCH22 in forum LinuxCNC (formerly EMC2)
    Last Post: 05-08-2016, 02:40 PM
  5. Computer suggestions to run Mach 3
    By DJR22013 in forum Mach Software (ArtSoft software)
    Last Post: 06-17-2015, 04:55 PM
