586,060 active members*
4,107 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc OI-MF control will not change tool 9
    Jun 2018
    First, Thanks for any help.
    This is a WOKE VMC with 24 tool changer and a Fanuc OI-MF control.
    All tool changer works fine except on tool 9.
    All other tools 0-8 & 10-24 load fine.
    In MDI or auto mode T9 gives an error: "EX1008 OVER COMMAND ERROR!"
    Any idea where the tool table is stored? I am guessing there is a bad number in tool 9.
    Thank, WAZP
    Dec 2009
    953
    Re: Fanuc OI-MF control will not change tool 9
    The tool numbers are stored in the DATA TABLE from 500 or 1000,depends on MTB,but if yiu look on the pages you will see your tools.
    Oct 2019
    17
    WAZP,
    I believe you can hit offset once or twice and plus over to tool management if it's been purchased and enabled for your machine.
    If it hasn't, EX1008 is a manufacturer's alarm, and you should be able to find the cause of it in the ladder.
  1. Replies: 2
    Last Post: 12-31-2014, 01:46 PM
  2. How to change Tool change position(About MAZATROL T1 control)
    By liushuixingyun in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2014, 01:33 AM
  3. tool change & tool control questions
    By Garage Elf in forum DIY CNC Router Table Machines
    Last Post: 09-06-2011, 10:41 AM
  4. manual tool change m2 control
    By metlshpr in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-11-2009, 01:58 AM
