586,094 active members*
3,971 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > S.O.S. SABRE 750 - ACRAMATIC 2100 (year 96)
Results 1 to 5 of 5
    May 2014
    174
    Hello dear friends,
    Anyone willing to lend a hand here, we are going through a crisis here where there is absolutely no tech support, we are located in South America. Our machine is a 1996 Cincinnati Milatron SABRE 750 with control ACRAMATIC 2100. and the system configuration parameters got mixed up.
    We are in desperate need of a set of parameters (backup archive) if some of you have a same type machine, we will greatly appreciate it. Many thanks in advance!
    Peloflex.
    Aug 2015
    100
    Re: S.O.S. SABRE 750 - ACRAMATIC 2100 (year 96)
    I cannot help you as I dont have your machine. However. In your other post I responded with someone who should be able to help you. Good luck.
    May 2014
    174
    Thanks a lot brother! God bless you!
    Dec 2006
    584
    Get on our web site to send me a email and I will send you what I have.
    Mike CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    ZanderGahel 02:51 AM Hoy
    Tengo un problema con un control Sabre 750 A2100 al que se cambió el codificador del husillo que controla la orientación ahora cuando la referencia genera la siguiente alarma 44-6 Falla de alineación de cuadrícula del eje C que creo que se debe a que el husillo no está orientado quería saber cuál es la forma de recalibrar el encoder y la orientación del husillo de antemano gracias.
  1. Sabre 750 Acramatic 2100 Error
    By flyinphill in forum Cincinnati CNC
    Last Post: 12-15-2023, 01:30 AM
  2. Cincinnati Sabre 2000 Acramatic 2100
    By Railer116 in forum Mori Seiki lathes
    Last Post: 09-17-2019, 03:40 PM
  3. Spindle or Drive Problem Sabre 750 Acramatic 2100
    Last Post: 06-09-2017, 02:26 AM
  4. Sabre 750 with 2100 Acramatic
    By Ernie in forum Cincinnati CNC
    Last Post: 02-26-2009, 03:29 AM
  5. Questions and/or Opinions about Cincinnati Sabre/Acramatic 2100
    By flyinphill in forum MetalWork Discussion
    Last Post: 10-29-2008, 11:10 PM
