586,069 active members*
3,410 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > GRBL 1.1 Cutting arc on the Z-axis using G2 command?
    Oct 2019
    7
    I have a piece I need to cut a 180 circle out of in the Z-axis. From what I've read, this would be supported by something like this...
    G91
    F100
    G2 X0Y0Z0 I0 J0 K-2
    But when I run that, all I get is "OK" back without movement. Any ideas?
    Aug 2009
    230
    Re: GRBL 1.1 Cutting arc on the Z-axis using G2 command?
    You have asked for a circle with zero radius. The arc commands work by moving to the start point, then in the g2/g3 command specifying the end point, and specifying the incremental distance in I and J words. Grbl mostly follows the gcode standard specifyed by Linuxcnc, so have a look at Linuxcnc’s reference documentation for g2 and g3 for more information.
    Oct 2019
    7
    thanks that helped... looks like needed to switch planes to XZ first and then attempt the move with I and J.
    G18
    G2 X0 Z0 I1 J-1 F50
    Yes, you need to change planes. Not sure if GRBL supports G18-G19 though?
    Aug 2009
    230
    G17, G18, & G19 are supported.
  1. 4th axis and GRBL with MEGA?
    By james_III in forum Arduino
    Last Post: 10-18-2018, 07:23 PM
  2. 5 axis with GRBL?
    By Stingray63Vette in forum Arduino
    Last Post: 07-17-2017, 01:10 AM
  3. Z Axis problem Grbl :-(
    By Gremlin76 in forum Post Processors
    Last Post: 08-02-2016, 10:37 AM
  4. GRBL 0.9j Unsupported Command
    By OldSalt1945 in forum DIY CNC Router Table Machines
    Last Post: 05-27-2016, 04:17 PM
  5. Z-axis hold and grbl
    By barjunk in forum Arduino
    Last Post: 06-03-2015, 08:31 PM
