586,061 active members*
4,423 visitors online*
Thread: 1"-8 tap
Results 1 to 7 of 7
    Sep 2005
    273
    1"-8 tap
    Hello, I'm tapping a 1-8 thread in 304L on a cnc lathe with rigid tapping, it's a 2-1/2 deep blind hole but have room for chips, minor is 3-1/2 deep, I was using a 4 flt hand tap but it broke on the 6th part, I was peck tapping at every 1/2 inch, I put in a spiral point 3 flt and wondering if I should peck or not seeing that the spiral point will push the chips ahead of the tap, I tapped one hole and looked like it was re-cutting the chip, try'ed to blow the chip off, didn't work, I'm using oil. any help would be great. thank's
    Dec 2013
    5717
    Re: 1"-8 tap
    I use these in 304. Blind Hole Inch Powertap Cut Taps - GUHRING
    But never a tried 1-8 in SS, normally 1/2-20. Don't even know if my lathe would rigid tap a 1-8. These do a nice job of pulling the chips out of the hole. Almost never have any chips left in the hole. If the spec will allow it, try a minor diameter of 0.9219 (59/64) This will give a 50% thread depth, standard for SS.
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2005
    273
    Re: 1"-8 tap
    Thanks for the reply, I'm leery of of the spiral flute taps kind of weak but I'll take a look, I know Guhring make's good stuff. Have you try'ed roll tap in stainless? strong tap for sure. if I have to I will single point the thread, taps are about $70 and up, gotta find something that's gonna work for the long run. thanks again
    Dec 2013
    5717
    Re: 1"-8 tap
    No, never tried form taps in stainless.
    I thread mill in my lathe 1''-8, 1.5'' deep for one part I make, in 6061, do it in one pass. Not sure there is a thread mill cutter with a shank 2.5'' long that would do a 1''-8
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2005
    273
    Re: 1"-8 tap
    This is a Samsung SL45 straight 2 axis lathe, no live tools or Y axis, just big, lots of power, 50 hp.
    Dec 2013
    5717
    Re: 1"-8 tap
    That's a lot of lathe Makes my Hardinge Conquest 42, 10 HP seem kinda wimpy.
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2005
    273
    Re: 1"-8 tap
    Haa, Iv'e run Hardings in the past, all the way back to the AHC and HNC days, Good machines, hold good size, I always hated the left handed control though but I see they do have some on the right now. I still use there 9136 deep hole macro. I'm very surprised how well this big lathe holds size, not bad at all. thanks
  1. Multi-head or multiple extruder simotanious "follow me" copy print "mirror mode"
    By routermaker in forum 3D Printer / 3D Scanner Discussion
    Last Post: 10-26-2019, 02:34 AM
  2. How can do ""manual stepper motor sizing for "rack and pinion"calculation""???
    By Medhat93 in forum Mechanical Calculations/Engineering Design
    Last Post: 03-03-2018, 01:50 AM
  3. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  4. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
