Thanks, guys!
@ger21, 1st answer: Ok, I understand that. But nothing "bad" can happen if I use 36 V instead of 62 V, right? And, if I understand correctly, it is then best to look for motors with lower inductance to efficiently use lower voltage?
@ger21, 2nd answer: Okay, but from what I saw, even the cheapest controllers for use with UCCNC are a lot more expensive than some cheap Mach3 breakoutboards. I could use my old PC and connect everything through parallel port and use Mach3. I plan to use the CNC for hobby purposes mostly, so I can't afford to buy controllers for 200 $ or so.
Do you see any problem in using this combination for my CNC:
BOARD:
https://www.aliexpress.com/item/3233...chweb201603_52
DRIVERS:
https://www.ebay.com/itm/Digital-DM5...AAAOSw~CVdExKj
MOTORS:
https://www.ebay.com/itm/EU-Free-Shi...oAAOSwBmhdchUr
