586,459 active members*
3,536 visitors online*
IndustryArena Forum > CAM Software > Mastercam > MASTERCAM 4 AXIS FEED RATE
    Jul 2016
    9
    I AM TRYING TO G CODE A 4 AXIS WRAPPING OPERATION IN MASTERCAM , I GET VERY SLOW FEED RATES .
    I AM USING GENERIC FANUC 4 AXIS POST .
    I HEARD OF INVERSE TIME AND THIS POST DONT OUTPUT G93 WHEN ACTIVING INVERSE TIME>
    HOW TO FIX THIS
    DID SOMEONE HAVE A POST FOR FANUC WITH INVERSE TIME.
    Aug 2015
    108
    Re: MASTERCAM 4 AXIS FEED RATE
    On the Parameters tab, left window towards the bottom. There should be a pull down menu labeled Axis Control.
    On Rotary Axis Control select Axis Substitution. It gives you two choices substitute X or Y axis. If the rotational axis on the rotary is inline with the X axis on your machine choose X, if its inline with Y choose Y.
    The Rotary Diameter, at the bottom, is set to the outside diameter of the part you have on the rotary. Say you want to cut a spiral groove 0.05" deep around a .75" bar mounted on the rotary. The Rotary Diameter window would have a value of 0.75. In your Linking Parameters, if the values were absolute, you would have top of stock at 0.0 and a depth of -0.05.
    Jul 2016
    9
    Quote Originally Posted by ERUS View Post
    Thank you for your help. I am asking for activing g93 of inverse feed time.
    I also have created a toolpath from a rolled geometry . When i tried to transform rotate toolpath the g code is not correct . How can i fix that
    Aug 2015
    108
    I cant get G93 active either. This is the best I can get from the code.
    G0 G17 G20 G40 G80 G90
    G49 G53 Z0.
    (CONTOUR)
    (COMPENSATION TYPE - WEAR COMP)
    M08
    M21
    T239 M6 ( 1/2 FLAT ENDMILL)
    M22 (UNLOCK)
    G0 G17 G90 G54
    X0. Y1.1074 S15000 M3
    G43 H#517 Z1.
    Z.1
    G94 G1 Z.0333 F150.
    Z-.0083
    Z-.05
    Y1.0512 F3498.05
    G41 D#517 Y.9957 F3892.75
    Y.9778 F3547.8
    Y.9589 F2356.11
    Y.9394 F1042.25
    Y.9198 F374.57
    Y.9006 F1882.4
    Y.8988 Z-.0101 F150.
    Y.897 Z.0298
    Y.8917 Z.0694 F369.61
  1. Newbie need help for FEED RATE for Z and X,Y axis
    By mcdoggie in forum G-Code Programing
    Last Post: 10-22-2017, 04:52 PM
  2. Mastercam feed rate
    By zarzavat in forum Mastercam
    Last Post: 08-06-2017, 09:22 PM
  3. 4th axis feed rate question
    By bcer960 in forum Mach Mill
    Last Post: 06-11-2015, 06:17 AM
  4. 4th Axis Feed Rate Problem
    By dkaustin in forum SprutCAM
    Last Post: 06-17-2011, 06:52 PM
  5. Z-axis feed rate
    By Richotech in forum Mach Software (ArtSoft software)
    Last Post: 08-03-2009, 03:13 PM
