586,121 active members*
3,173 visitors online*
    May 2017
    7
    Question Voltage regulator for Chinese CNC router
    Hello
    I want to connect the CNC router to a voltage regulator. How many KVAs to choose?
    CNC router 1300x2500
    4 motors
    spindle 380V, 3.2kw, 7A, 400Hz, 24000 rpm
    thanks
    Jan 2007
    626
    Re: Voltage regulator for Chinese CNC router
    I think you may mean 'Step Down Transformer'? Is your supply voltage too high?
    If I have got it wrong, can you please elaborate. I'm guessing English is not your first language.
    We are going to need more info....
    May 2017
    7
    hello Sterob and thank you for your reply.
    1 - its true , English is not my first language.
    2 - i want to protect my cnc router machine with automatic voltage regulator.
    one like this for example.
    and i need to know , how many KVA to choose?
    thank you.
    Jan 2007
    626
    Ok...You must have wild voltage fluctuations in your area?
    Your Spindle is rated at 3.2kW and that would be most of the load.
    I would think that you would be ok using a 3.5 kVA AVR or if you wanted to be extra safe, maybe 4.0 kVA. depending on what sizes are available.
    The worse your Power factor is, the higher the kVA rating has to be.
    Cost will probably a consideration as well.
  1. Chinese VFD - Wrong Voltage?
    By firepong in forum Spindles / VFD
    Last Post: 06-13-2018, 05:36 AM
  2. chinese drive voltage compatability
    By dix2111 in forum Phase Converters
    Last Post: 09-05-2010, 06:43 PM
  3. Voltage regulator on a CNC power supply
    By boatlover in forum CNC Machine Related Electronics
    Last Post: 06-10-2008, 05:00 AM
  4. voltage regulator chips.
    By Mcgyver in forum CNC Machine Related Electronics
    Last Post: 12-19-2005, 03:32 PM
  5. router speed regulator
    By Hobbiest in forum CNC Machine Related Electronics
    Last Post: 01-27-2004, 11:36 PM
