586,052 active members*
3,935 visitors online*
Results 1 to 6 of 6
    Apr 2011
    720
    Engraving tool style
    Hi All
    I saw this tool in an advert I received from Harvey tool, and thought is looked like it would leave a nice engraving tool path, but also thought it looked delicate as heck.
    I was just curious if anyone had any experience with this, or a similarly shaped tool?
    Terry
    Aug 2009
    230
    Re: Engraving tool style
    It will, and it probably is. I've not used that particular bit, but I have used bits that are typically used for PCB routing - and at small sizes, yes, they are quite delicate. A "V" style bit will be much tougher, but obviously leaves a different cut path.
    Aug 2013
    980
    Most of my engraving is on mild steel. I tried the v-points but I found the Kyocera 1/32” 4-fl Bn stub endmills work the best for me and holds up longer than v-points.
    Plus the edges are not as pronounced and it takes less time de-burr/tumbling
    If you are using it on aluminum you may want to use v-points
    QUOTE=MFchief;2328650]Hi All
    Terry[/QUOTE]
    Mar 2011
    480
    Quote Originally Posted by MFchief View Post
    Hi All
    Terry
    Never used one, but if it's Harvey, probably works great.
    I use a .125 ball mill .005 deep. Looks real nice if you don't need tiny letters.
    Nov 2007
    2151
    Quote Originally Posted by AUSTINMACHINING View Post
    Good idea, I was just setting up some new parts and was using a v bit like mentioned above. This might be a little smoother looking for this model. Then again I might skip those ops and just do the lettering in conversational. I don't always like the text I can draw and import into cam models. But still experiment with small ball end mills - depth/path and font for something I like.
    Apr 2011
    720
    I think I will give one a try, Harvey does have a good reputation, and I can get one for about $23.00 Only down side I see, other that delicacy, is they only cut one width so if you do a lot of different size engravings, it would add up quickly.
    Terry
  1. HSK Style Tool Holder Manual Tool Change Spindles
    By tinmancarving in forum Spindles / VFD
    Last Post: 10-01-2018, 08:05 PM
  2. Instructions of MORN newest laser engraving and cutting machine style
    By Morntech2008 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-19-2014, 08:47 AM
  3. Happy new year~ New style of laser engraving machine show
    By RoseChina in forum News Announcements
    Last Post: 01-03-2014, 01:41 PM
  4. Carousel Style Auto Tool Change CNC Router
    By cherry.CC in forum News Announcements
    Last Post: 02-17-2013, 04:55 AM
  5. Pyramid style engraving bits
    By PEU in forum PCB milling
    Last Post: 08-28-2011, 09:52 AM
