586,069 active members*
3,425 visitors online*
Thread: Simulation
Results 1 to 7 of 7
    Simulation
    Hi everyone,
    Does pathpilot have any kind of simulation at the controller for a simple conversational program? We are considering getting the 1100m mill and we haven't found any information on it. It would be nice to see what happens before the cycle start button is pushed in a isa viewpoint on the main tab.
    Apr 2010
    60
    Re: Simulation
    Not so much as a simulation as much of a preview of tool paths with overall size and maximum work areas identified, typically it is enough information too identify if something is wrong. If you would like you can tinker with pathpilot here before you buy to learn how it works. Virtual.pathpilot.com . For me Pathpilot is awesome and allowed me to learn more about CNC and Gcode than I ever thought I would.
    Attached Thumbnails Attached Thumbnails 31B26CF2-725A-4EC3-9606-B4B02C40567B.jpg
    Re: Simulation
    Thank you. That will help out a lot. I like gunsmithing and those grips look awesome.
    Nov 2007
    2151
    Re: Simulation
    Complex models and tool paths are best developed in cam software from models. For small conversational programs its easy enough to simulate at mill by setting xyz start point above vise and run program milling air. Not that long ago it was a good idea to test all new code this way.
    Jul 2018
    6339
    Re: Simulation
    Have a look at https://camotics.org/ its free and simulates toolpaths. Peter
    Sep 2009
    624
    Re: Simulation
    Quoting Tormach, 10 years ago: Always run your code in foam first.
    I use the cheap pink stuff. It's amazingly dimensionally stable, normally a dead match to a metal part even on thin/close features. Easy to check both finished part and toolpaths. Running a foam doubles -or more- time for every part I make (everything is a one-off). That practice has saved hundreds in tooling costs and scrap.
    Re: Simulation
    Thanks for that, I'll check it out.
  1. 5.0 Simulation bug?
    By declanhalpin in forum MadCAM
    Last Post: 03-10-2013, 06:40 PM
  2. Simulation
    By Runtime_error in forum SIEMENS -> GENERAL
    Last Post: 02-03-2012, 03:24 PM
  3. CAM Simulation OK but........
    By masterfabr in forum Fadal
    Last Post: 02-16-2010, 09:06 PM
  4. Simulation
    By Wulda in forum HEIDENHAIN -> GENERIC
    Last Post: 02-17-2009, 03:42 PM
  5. Simulation only ?
    By patrickb in forum FeatureCAM CAD/CAM
    Last Post: 05-27-2006, 02:01 PM
