586,036 active members*
3,576 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > machine all the time in rmt mode
Results 1 to 7 of 7
    Oct 2019
    hello
    just like the subject, the machine is still in rmt mode
    the machine is a milling machine SMC8650 with fanuc Oi MF software
    despite turning the potentiometer to other modes (e.g. edit) the machine is still in rmt mode
    What should you do to make the machine go into other modes?
    in addition, nothing can be turned on from the operator panel, e.g. coolant or block-by-block mode
    after resetting the PLC ladder and switching to manual activation, the machine goes into a different mode with a potentiometer but nothing else
    Oct 2019
    17
    Re: machine all the time in rmt mode
    This requires way more information than you have provided.
    When did this start happening?
    Are you able to bring the machine out of E-Stop?
    What do you mean "nothing can be turned on" from the op panel?
    What do you mean you "reset" the ladder?
    As someone who troubleshoots machinery for a living, I can tell you that you gave very little information.
    Quote Originally Posted by Danielos91 View Post
    hello
    I have a Takisawa TS-25 with 15TF control. IT has akeep relay setting that selects between tape/rmt and local/memory mode. Not sure of this is The case for you, but might help.
    Mar 2017
    314
    resetting the PLC ladder?
    An 0i-MF (the current model) would not have Tape/Rmt mode
    After a bit of research I think you are in the wrong sub-forum
    Just because chairman Mao put a Fanuc sticker on it doesnt make it a Fanuc
    I think this is what you have. But who knows.
    GSKCNC.com GSK CNC Equipment CNC Machine AC Servo Motor Servo Drive CNC Controller CNC Milling CNC Lathe Turning OEM Stepping system Ball Screw Power American Chinese made China
    Dec 2009
    953
    can you upload the ladder so we can open it and search for your problem?
    Apr 2020
    5
    Hi
    Do you solve your problem? My also CNC Milling machine, system also Fanuc 0i mf. I just install. I can not use. What happened, I don’t know? Can anybody help?
    Nov 2022
    I do have the same problem with the same machine Please help ????.
