586,069 active members*
3,302 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > spindle speed not changing
Results 1 to 15 of 15
    Apr 2008
    27
    need some help with Chinese VFD also using MX 4660 and smooth stepper and Mach 3
    i've double check the wiring everything is correct but I'm having trouble with the settings and Mach 3
    if anybody be willing to work with me to get this figured out because I am pulling hair
    when I start the spindle it runs 7174 but I can't change the speed at all
    thanks much
    15362
    Re: spindle speed not changing
    Quote Originally Posted by thunderbite View Post
    thanks much
    First you have to check 0-10v is working from the Breakout Board and this changes with the M3S12000 should be 5v
    VFD Drive Model and number Manufacture
    Mactec54
    Apr 2008
    27
    VFD is a Haunyang model HY03D023B 3ph 3.0KW 13A
    controller is a MX4660 when I tested from this unit 0-10v after I run M3 s18000 I got no reading what so ever using my volt meter going to ground. When I did the test I did not have the VFD on if that makes a difference
    15362
    So you have to look at the configuration of the controller MX4660 you have to get this part working before looking at the VFD Drive
    Did you supply the 10v / 12v to the MX4660 for the PWM output of 0-10V
    Mactec54
    Apr 2008
    27
    so I changed the wiring from the VFD to the MX4660 per the instruction from Leadshine manual and the spindle starts and is running at about 15000rpm no matter if I input a speed or just start the spindle
    an I get 1.1 volts across port "+10vdc in" and the GND and still can not changed the speed in mach 3
    answer your last question is yes
    PD001=1
    PD002=1
    PD003=300
    PD004=300
    PD005=300
    PD006=2.5
    PD007=.50
    PD008=220
    PD009=.13
    PD010=6.5
    PD011=11
    PD013= Nul
    PD014=5
    PD015=5
    PD044=1
    PD070=0
    PD071=20
    PD072=300
    PD073=120
    PD141=220
    PD142=8.6
    PD143=2
    PD144=2000
    15362
    PD001=1
    PD002=1
    PD003=300
    PD004=300
    PD005=300
    PD006=2.5
    PD007=.50
    PD008=220
    PD009=.13
    PD010=6.5
    PD011=11
    PD013= Nul
    PD014=5
    PD015=5
    PD044=1
    PD070=0
    PD071=20
    PD072=300
    PD073=120
    PD141=220
    PD142=8.6
    PD143=2
    PD144=2000
    Mach3 can be tricky to get right which seems to be where your problem is, if you have no voltage change then something in the Ports and Pins may need to be changed
    All your basic settings look ok
    PD144 should be 3000 for it to work correct
    Jumper J1 set to 1-2
    PD044=02 default this is not normally changed
    PD174= ??? ( To Be Set to the VFD Drives Max Rated Output Amps )
    Mactec54
    Apr 2008
    27
    Jumper J1 in on 1-2
    I will check PD044 and change it to 2
    I will also check PD174 and set it to the correct amp of the motor not sure were it is at this time
    be back at it tomorrow afternoon doctors apt in morning
    Thanks for your help so far
    fyi I'm getting PWM errors also
    Later
    15362
    Jumper J1 in on 1-2
    Later
    PD144=3000 not 2000 this should get you to your spindle max 18,000RPM with KeyPad control
    If you are getting a PWM errors then you need to look at your wiring there could be a problem how you have this connected
    Mactec54
    Apr 2008
    27
    IQUOTE=mactec54;2329880]PD144=3000 not 2000 this should get you to your spindle max 18,000RPM with KeyPad control
    If you are getting a PWM errors then you need to look at your wiring there could be a problem how you have this connected[/QUOTE]
    I changed the Pd144 to 3000 and running it with keypad it ran at 17952 close enough for me
    the slowest I could get the Spindle to run is 9000 using my hand held. Digital Tachometer
    the PD174 was at 11.0 and I could not change it to any thing else
    I contacted Leadshine and he stated that The PIN14 of DB25 is used for PWM signal transmission and to Configure pin14 for spindle control so that leaves me to these pic
    I also was correct with the wiring per Leadshine
    I
    15362
    I[/QUOTE]
    Ok I see another Parameter problem with the minimum speed is your spindle air cooled or water cooled ???
    PD011=120
    What is the Breakout Board you are using
    Mactec54
    Apr 2008
    27
    I
    PD011=120
    What is the Breakout Board you are using[/QUOTE]
    Apr 2008
    27
    It is air cooled
    the breakout board is a Lendshine MX4660
    I will check on PD011
    PD011=120
    I did some research and found that one other user of the MX4660 was testing his Estop button and the MX failed so they replace the unit and he installed a jumper on the to E-stop ports and he never connected the button again.
    15362
    It is air cooled
    PD011=120
    Ok I will look at the manual
    So what I found was they are using the 12v supply from the MX4660 to power the 10v supply, not the 10v supply from the VFD Drive
    (1) Used MACH3, settings: PWM Base Freq. = 10, Minimum PWM = 0%,
    (2) Used “+12Vdc Out”, the 12VDC auxiliary power output on the MX4660 as the power input for “+10Vdc in” of the VFD (The measured value of the “+12VDC auxiliary power output of the MX4660” was?11.98VDC.).
    Mactec54
    Apr 2008
    27
    Hay Thanks for all your info (HELP) but I'm going with a RS485 connection instead of using the MX4660 for spindle control. It will do what I want it to do, at least that what he said on the CNCnutz Episode 147
    and I only need one twisted pair of wires from the RS485 to the VFD do some config on each of the units and I should be up and running. I will only use the MX4660 for the Axis.
    The RS485 should be here on Friday. I will down load the Plugin from this web site https://www.cncnutz.com/2017/05/mach...trol-with.html. This plugin is only use for the Huanyang inverter
    I will let you know how it turns out
    15362
    Yes this is the way to go when all else gets to be a problem, I did see some strange settings you have in Mach3 Ports and Pins which could of been where your problems are there are a few Modbus connections that work well with your VFD Drive
    Mactec54
  1. Replies: 7
    Last Post: 12-07-2014, 03:23 PM
  2. Changing Kernel speed
    By dsnellen in forum Mach Mill
    Last Post: 09-08-2013, 11:25 PM
  3. Changing the spindle speed on a thread
    By cSpampinato in forum Mechanical Calculations/Engineering Design
    Last Post: 09-05-2012, 02:45 PM
  4. mach3 spindle dro not working, spindle speed changing while jogging and running code
    By jasminder in forum Mach Software (ArtSoft software)
    Last Post: 02-23-2011, 07:12 AM
  5. Replies: 9
    Last Post: 08-06-2009, 05:26 PM
