586,108 active members*
3,161 visitors online*
    Oct 2019
    20
    Oil pump info
    Does anyone have a english manual for the pump in the pic
    Apr 2018
    24
    Re: Oil pump info
    Re: Oil pump info
    • Set button?
    1. Press this button, you can pump the oil again, or you can reduction and elimination the alarm.
    2. Press this button 2 seconds, and then reverse it, you can set the ACT(actuation) time, and then press this button 2 seconds again, you can set the INT(interrupt) time, and then press this button again, the set is done.
    • [IMG]file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image002.jpg[/IMG]?change the ACT(1-999 seconds) and INT(1-999 minutes) time preminum.
    • Reset button?fuction same as set button’s function 1, this button is at the right side of the cover.
    • After power on, the system will be ACT oil state, and the system will be ACT and INT circle, the ACT gree light and INT red light will be light up circulatory. The display time will be decreasing by your setting.
    • “Er0” twinkle means oil is not enough, “ErP” twinkle means pressure is abnormal, “Ers” twinkle means system timeout operation failure.
    The series of insulating oil purifier that we can provide are:
    Series ZY: Zhongneng Vacuum Insulation Oil Purifier.
    Series ZY-A: Zhongneng Vacuum Insulation Oil Automation Purifier.
    Series ZY-R: Zhongneng Vacuum Insulation Oil Regeneration Purifier.
    https://digitejarat.trade/category/w...-manufacturers
    Series ZYD : Zhongneng Double-Stage Vacuum Insulation Oil Purifier
    Series ZYD-A: Zhongneng Double-Stage Vacuum Insulation Oil Automation Purifier
    Series ZYD-R: Zhongneng Double-Stage Vacuum Insulation Oil Regeneration Purifier
    https://digitejarat.trade/category/o...-manufaturers/
    Series of turbine oil purifier that we can provide are:
    Series TY : Zhongneng Vacuum Turbine Oil Purifier.
    Series TY-A: Zhongneng Vacuum Turbine Oil Automation Purifier.
    eries TY-R: Zhongneng Vacuum Turbine Oil Regeneration Purifier.
    Series of lubricating oil purifier that we can provide are:
    Series LY : Zhongneng Vacuum lubricating Oil Purifier.
    https://digitejarat.trade/motor-oil-...plant-in-iran/
    Series LY-A: Zhongneng Vacuum Lubricating Oil Automation Purifier.
    Series LY-R: Zhongneng Vacuum Lubricating Oil Regeneration Purifier.
    Oct 2019
    20
    Re: Oil pump info
  1. Pump help
    By peterklos in forum Waterjet General Topics
    Last Post: 06-19-2018, 01:21 PM
  2. Replies: 0
    Last Post: 11-15-2017, 04:19 AM
  3. Looking for Info, Patent #'s, Info on Milling Machine Automatic Tool Changers
    By CNC-Joe in forum Uncategorised MetalWorking Machines
    Last Post: 08-22-2013, 05:41 PM
  4. Vac Pump Help
    By redvanth in forum Chinese Machines
    Last Post: 09-15-2011, 03:52 AM
  5. Charge Pump DIY Info, Circuit, Design, PCB???
    By HayTay in forum CNC Machine Related Electronics
    Last Post: 07-09-2006, 03:47 PM
