586,119 active members*
3,580 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > How to go about getting om-c ladder edited for dnc function
    Sep 2019
    15
    Hi i have a miyano tsv-35 and it dose not have tape or dnc modes , no switches on the control . I am able to see the ladder and searched for g127.5 and its not there . Is it possible to have it added ? who or where would do this ? i currently only have 48k memory and can only run small programs . I have found some info on upgrading the memory but if possible id like to be able to drip feed my machine . any info would be greatly appreciated . Thanks
    Re: How to go about getting om-c ladder edited for dnc function
    I have a YCI Supermax with OMC. M50 and M51 turn DNC on and off. Not sure which is which. I think M51 on. If I find out different tomorrow at work I'll correct this. Can't promise this will work on your machine. You also need software to drip feed to your machine. dnc4u is what I use. Works great.
    24221
    There is a few older posts on the subject e.g. https://www.cnczone.com/forums/fanuc...m-ladders.html
    You need to find someone, hopefully local that has the Fanuc eeprom burner in order to program and store the modified ladder.
    Al.
    Albert E.
  1. Replies: 3
    Last Post: 01-11-2019, 05:32 PM
  2. CAD files can be edited in VCarve Pro but not in Cut2D. Valuable feature?
    By CarySwoveland in forum PhotoVCarve and VCarve Pro
    Last Post: 05-20-2014, 06:34 PM
  3. x2 or Sherline *edited*
    By slim_mif in forum Benchtop Machines
    Last Post: 04-10-2009, 05:31 AM
  4. How do I load an edited G code program
    By Stile2 in forum MadCAM
    Last Post: 05-22-2006, 09:26 PM
