586,112 active members*
3,068 visitors online*
    Sep 2019
    54
    Servo suggestions
    Hi all, in process of revamping esab table
    I was hoping to use the existing motor and gearboxes,
    I have now found out what the motor's are,
    They are the exact same as the
    M642TE brushed servo motor DC with built in tachometer,
    I am not to up to date with servo
    As I always worked with only steppers before
    Would anyone know what all would be needed to run these from mach3 or some other modern controller
    As in motion controllers and drivers
    24221
    Re: Servo suggestions
    I did an old Gas tracer table converted to CNC, but used BLDC servo's and 10:1 gearboxes, and Galil Motion controller in a PC.
    Current controllers no longer use a tach, as long as they have an encoder on the motor, then you should be able to use a suitable controller, step/dir etc.
    Al.
    Albert E.
  1. RSF linear encoder DC servo motor suggestions
    By johndmcmaster in forum Servo Motors / Drives
    Last Post: 12-27-2023, 04:03 AM
  2. Help with servo suggestions
    By Dem1 in forum Servo Motors / Drives
    Last Post: 09-11-2019, 10:53 PM
  3. Suggestions for low-voltage high-resolution servo
    By Storen in forum Servo Motors / Drives
    Last Post: 09-02-2018, 11:50 PM
  4. Replies: 1
    Last Post: 08-28-2018, 01:05 PM
  5. Servo's and noise suggestions
    By ty1295 in forum CNC Machine Related Electronics
    Last Post: 11-09-2004, 02:59 PM
