586,069 active members*
3,484 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Down Okuma LU300, P200L - Does anyone have these CD files
    Jul 2017
    25
    Exclamation Down Okuma LU300, P200L - Does anyone have these CD files
    Hello, I have an Okuma LU 300 with P200L controls. I need to install the osp system software, but I only have [CD 2]. Could anyone share the files for [CD 3]? That would be a great help! I would like to get my machine up and running tonight for 3rd shift to run some orders.
    I am unsure if another persons CD from a machine will work on my machine? If they are the same machine and controls, I would assume so?
    Thank you!
    Jun 2015
    4154
    Re: Down Okuma LU300, P200L - Does anyone have these CD files
    hi, cd's are pretty machine specific, especially the osp [ maybe cd2]
    cd3 may contain the model data, thus it is <> osp, so maybe you can start your machine only by installing cd2, but so far i never tried this
    even if it works, do some testing, especially if the machine is used on 3rd shift
    look on the hdd, maybe there is the kit copied on it, from the previous installation; why is needed to re-install the osp ? kindly
    Jul 2017
    25
    I found the CD #2 and installed. Our hard-drive is showing internal hard-ware fault, RAM / memory parity error. So either issue is in RAM or hard-drive. I found another hard-drive for same controls (P200), so I had to install osp software and "restore" my parameters and user data file to this. I was able to get my program opened up, but I am still getting the hardware fault, so maybe the issue is in the RAM card. I am working to change out RAM card today.
  1. OKUMA LU300
    By Antonio Arguijo in forum Okuma
    Last Post: 06-23-2019, 09:03 PM
  2. Okuma LU300 OSP-E100L Force I/O
    By MidlandMachine in forum Complaints and Praise Discussions
    Last Post: 02-08-2019, 02:55 PM
  3. Okuma OSP-P200L
    By sadon in forum Okuma
    Last Post: 08-12-2017, 07:48 PM
  4. Okuma ops p200l how to ues usb port.
    By Twin-10s in forum Okuma
    Last Post: 08-12-2014, 03:03 AM
  5. turning direction AW Okuma LU300-M
    By shame.wtal in forum Okuma
    Last Post: 06-04-2010, 04:54 PM
