586,060 active members*
3,903 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > For Sale Only > For Sale: New Flow Paser CF900 Dual Stage Continuous Feed Hopper
    Brand new Flow Paser CF900 Dual Stage Continuous Feed Hopper. We ended up upgrading to a larger system and this was never used. It is still in the original shipping crate and was only opened to take the pictures. We purchased it for a Flow Mach 500 and do know that it is compatible with the Flow Mach 100, 200, 300 & 500 series waterjet machines. Please do your research on what other machines this unit is compatible with.
    Asking $4000 + shipping or best REASONABLE offer.
    Shipping is responsible by the buyer from Hayward, Ca. Local pickup in Hayward is also available, please contact me to arrange pickup. We will help to load the unit on a freight truck or your trailer if needed. Thanks for looking!
    The PASER CF900 Abrasive Delivery System (ADS) is designed for the continuous transport of abrasive materials. A programmable logic controller (PLC) constantly monitors the level of abrasive, and a control cabinet provides visual and audio feedback.
    Specifications
    Dimensions (LengthxWidthxHeight) .................................................. 858x858x1392 mm (33.8x33.8x54.8 in.)
    Weight .................................................. .................................................. ................. 112 kg (247 lb) empty
    .................................................. .................................................. ................................ 537 kg (1184 lb) full
    Abrasive capacity .................................................. .................................................. ............ 425 kg (937 lb)
    Customer air supply .................................................. ....................................... has lockout/tagout capability
    Customer air supply line .................................................. .................................................. >20 mm (3/4 in.)
    Operating pressure/volume .................................................. ................ 5.5 bar (80 psi) @ 566 lpm (20 scfm)1
    Surge pressure/volume .................................................. ...........5.5–6.5 bar (80–94 psi) @ 2250 lpm (80 scfm)
    Maximum compressed air volume ............................................... dependent on abrasive material and flow rate
    Quality of compressed air .................................................. ..........................................dry and filtered to 10µ
    Supply voltage .................................................. .................................... 100–240 VAC, 50/60 Hz, or 24VDC2
    AC Frequency .................................................. .................................................. .......................... 50/60 Hz
    Full-Load current .................................................. .................................................. .......... 0.20 A@ 240VAC
    .................................................. .................................................. ................................. 0.48 A @ 100 VAC
    .................................................. .................................................. .................................... 2.0 A @ 24 VDC
    Largest-load current........................................... .................................................. ............................... 2.0 A
    Rating (SCCR)............................................ .................................................. .....................................2.5 kA
    Site.............................................. .................................................. ...................................... Level and solid
    Operating environment temperature .................................................. .........................0°C–55°C (32°F–131°F)
    Operating environment relative humidity .................................................. ......................................... 5%–95%
    Operating environment elevation .................................................. ........... 0–2500 m (0–8200 ft) above sea level
    Service clearance .................................................. ...................................... 1 m (3 ft) on front and sides
    1Requires a minimum of 2 bar (30 psi) difference between the supply pressure and the operating pressure.
    Sound level, conveying abrasive .................................................. ........................................... 69.6 dBa3
    Sound level, depressurization .................................................. .................................................. 98 dBa3
    Sound level, repressurization .................................................. ................................................ 79.4 dBa3
    Attached Thumbnails Attached Thumbnails IMG_4163.JPG   IMG_4162.jpg   IMG_4165.JPG   IMG_4164.JPG
    Re: For Sale: New Flow Paser CF900 Dual Stage Continuous Feed Hopper
    Price drop, $3300 + shipping from 94544 (+ PayPal fees)
    Thanks for looking!
    Jul 2022
    Do you still have this CF900
  1. Replies: 0
    Last Post: 03-27-2018, 06:42 PM
  2. CW-5200 water chiller flow alarm but flow is fine
    By dogeatdog5 in forum For Sale Only
    Last Post: 03-12-2018, 11:32 PM
  3. lathe dual feed part help
    By houdini in forum GibbsCAM
    Last Post: 08-28-2014, 03:06 PM
