586,033 active members*
3,430 visitors online*
    Jan 2013
    Problem with mach 3 when using G00
    Hello CNC geeks,
    I am facing a problem hen using rapid movement G00 with mach3, when I use it with Y-Axis, it always add 25 mm, for example if I want Y-Axis to 7 cm, the DRO gives 72.5 mm, if I move from machine home 10 cm using G00, the Y-Axis moves 102.5.
    Any Ideas?
    Apr 2004
    5737
    Re: Problem with mach 3 when using G00
    It sounds like you've got the anti-backlash settings set wrong.
    Andrew Werby
    Website
  1. mach 3 problem
    By Millsy in forum Mach Software (ArtSoft software)
    Last Post: 09-27-2017, 01:28 AM
  2. mach 3 problem
    By nosheds in forum Mach Software (ArtSoft software)
    Last Post: 10-20-2016, 01:56 PM
  3. mach 3 problem
    By ellard in forum Machines running Mach Software
    Last Post: 04-16-2009, 12:53 AM
  4. mach 3 problem
    By ellard in forum Canadian Club House
    Last Post: 04-15-2009, 06:01 AM
  5. Jog problem with Mach 2
    By jtriggs in forum Mach Mill
    Last Post: 06-15-2006, 06:48 AM
