586,112 active members*
3,070 visitors online*
Results 1 to 2 of 2
    Oct 2019
    Second offset on groove tool
    Hi, in need to set 2 different offset on turning groove tool. Couldn't make it.
    Please your good help.
    Re: Second offset on groove tool
    Hi Matgo,
    Say you're tool is mounted in turret position one, so you call T0101 to bring that tool to play and activate the first offset you have for it. Now pick any other offset number that isn't being used by another tool, Let's use 8 just for explanation's sake. Set the 2nd offset you want for tool one there in Geometry 8 address, (be it X or Z or both) just like you did for tool one's first offset. Now when you want to use the 2nd offset for tool one just call T0108. And there you have it. Simple. You can use that same concept to have as many offsets as you think you want for your tool, as long as they're not being used by another tool.
    Dave
    PS - Now if you're trying to do this from within Solidcam or want Solidcam's post processor to spit it out for you... you're on your own there. The above is hand work either in your G code or at the machine or come to think of it... both.
  1. Replies: 9
    Last Post: 04-03-2024, 09:33 PM
  2. Replies: 5
    Last Post: 03-17-2019, 05:05 AM
  3. lathe groove back offset
    By NV529 in forum Mastercam
    Last Post: 06-01-2012, 10:20 PM
  4. Tool offset with work offset
    By botha.y in forum SIEMENS -> GENERAL
    Last Post: 05-28-2012, 09:48 PM
  5. V-groove tool
    By zewanil in forum WoodWorking Topics
    Last Post: 08-01-2009, 07:12 PM
