586,061 active members*
4,596 visitors online*
    May 2013
    165
    Softjaw Design Question
    I've just recently made my first set of soft jaws for my Haas mini mill, and I'm wondering if the holes for the two bolts that secure it to the vise should purposely be over sized to allow some movement in all directions until the bolts are tightened up?
    Also should the holes be perfectly round, or should it be a slot style hole up and down to allow the soft jaw to slide up and down till the bolts are tightened?
    When I made my first set I tried to get the holes as close as possible to the diameter of the bolts so that when I removed and reinstalled the soft jaw that it would be placed back into the exact same location, but I'm not sure if this is the right approach.
    Kent
    Dec 2013
    5717
    Re: Softjaw Design Question
    In most cases you want to size the hole for normal clearance (1/32''). This will allow a little float. If the jaws need to be precision located, then take a cut on the locating surfaces before starting the job to insure accuracy.
    I normally put a generous chamfer on the bottom side of the soft jaws to be able to take a cut on the faces after installation if needed.
    Jim Dawson
    Sandy, Oregon, USA
  1. Design Question
    By ynnek in forum DIY CNC Router Table Machines
    Last Post: 08-19-2016, 05:57 PM
  2. New design - Quick question about my design
    By guerd87 in forum DIY CNC Router Table Machines
    Last Post: 02-14-2010, 07:35 PM
  3. Design question. Why is it so? XYZ
    By voltsandbolts in forum Open Source CNC Machine Designs
    Last Post: 01-08-2009, 03:09 PM
  4. Design question
    By Jay325e30 in forum Waterjet General Topics
    Last Post: 10-06-2008, 11:27 AM
  5. Design question
    By AndyL in forum DIY CNC Router Table Machines
    Last Post: 04-01-2007, 09:54 PM
