586,112 active members*
2,999 visitors online*
    Sep 2005
    250
    Does a Sem motor have a brake ?
    Good Morning ,
    I am in the process of replacing the SEM motors ( MT30M4-24 ) on my Bridgeport 412 machines and i found a company that have replacement motors but they asked me if the motor has a built in brake, I believe it does but i am not 100 % sure. I do not want to take one of the apart to find out because they are still working. I am hoping someone here can help me out.
    Thanks in advance !!
    Apr 2015
    170
    Re: Does a Sem motor have a brake ?
    Quote Originally Posted by RMARCH View Post
    Good Morning ,
    I have never seen a SEM servo motor with a brake, maybe there is one on the "Z" axis. Just look inside the terminal box and look at the connections, there will be 2 thick wires for the motor, 2 thin ones for the thermal overload and two more thin ones for the tacho. If there is a brake there will be an additional 2 wires. You can easily check them with a multimeter. The thermal overload ones will have little or no resistance, the tacho will have a static resistance of around 60 ohms and will generate a voltage when the shaft is turned. Also if there is a brake there should be some indication on the name plate of the motor. Dave
    Apr 2015
    170
    Quote Originally Posted by Bdrangdo View Post
    I forgot to add that most servo brakes are by default on, ie they require power to release, spring pressure is used to apply the brake, so if the motor shaft is free to turn then it is unlikely to have brake fitted. Dave
    Sep 2005
    250
    I Decided to take the Sem motor apart to be sure and there is NO Brake.
  1. Servo motor brake
    By damunk in forum Servo Motors / Drives
    Last Post: 06-20-2017, 03:28 PM
  2. 600mm Box bend brake (Finger Brake, pan Brake)
    By RotarySMP in forum Bending, Forging, Extrusion...
    Last Post: 11-01-2015, 10:24 AM
  3. DC Gear motor and power off brake(on the load side not on motor)
    By glomagno in forum Mechanical Calculations/Engineering Design
    Last Post: 04-10-2014, 05:41 AM
  4. disassemble brake on a2/3000 motor ?
    By jmelson in forum Fanuc
    Last Post: 07-25-2011, 04:02 AM
  5. Z AXIS MOTOR WITH BRAKE
    By Russ Shugg in forum Servo Drives
    Last Post: 10-26-2009, 08:45 PM
