586,069 active members*
3,455 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OKUMA OPS Control Force I.O
Results 1 to 7 of 7
    May 2017
    6
    Can any one help me to show How can I turn on the function for force l input and output signal for OSP control ?
    I read the manual book. To force the signal the OSP control should be change to Adjustment mode. But I do not know how to change to adjustment mode.
    I notice the have a function for " Change PLC Mode ", this need a password? Did PLC for OSP control have any default password ?
    Thank you.
    Jun 2015
    4154
    Re: OKUMA OPS Control Force I.O
    hy honghaivib, pls check attached for osp300; watch in order 01 02 03 04 and 05; don't forget to cycle the power ( off and back on ) after 03
    if i may, what signal do you wish to mix-in-the-mix, and why ?
    1st time when i read the title of your post, i believed that you wish to control the torque limit, thus the output force : somehow, that's also possible kindly
    ps : sorry 4 the delay, i was dirty ...
    May 2017
    6
    Thank you DeadlyKitten !
    So the password I can use is : CHGCOND? It can apply for all machine with OSP control?
    my factory have a lot of Okuma machine with OSP control. Some time I would like to turn on or off some input or output for troubleshooting. Example I turn on the signal to the valve to test the valve working or not.
    Jun 2015
    4154
    i don't know many things ... give it a try
    please, if i may, what are you controling with those valves ? kindly
    May 2017
    6
    Thank Deadlykitten !
    I already test the cnc okuma machine with the password you gave me. I work for type of OSP control in my factory.
    Some time I test the coolant pump, some time I test hydraulic valve for chuck clamp and unclamp....
    Do you know how to force input and output signal of CNC machine with Sinumerik control ? It need password too
    Jun 2015
    4154
    hy, i thought that you have extra-valves, controlling some custom automation; so far i had no problems with the default valves
    no clue about sinumerik ... try to contact the dealer ? sinumerik forum ? or be a hacker / kindly
    ps : use the force, honghaivib !
    So the password is CHGCOND? Does this apply to Okuma OSP-100 and 200 systems?
  1. Okuma LU300 OSP-E100L Force I/O
    By MidlandMachine in forum Complaints and Praise Discussions
    Last Post: 02-08-2019, 02:55 PM
  2. HELP With Okuma 5020L Control
    By pacetool in forum Okuma
    Last Post: 08-07-2015, 01:23 AM
  3. Actuator force control
    By dmorton in forum Linear and Rotary Motion
    Last Post: 07-12-2011, 12:58 AM
  4. Okuma OSP 2200 Control
    By cnccontrols in forum Okuma
    Last Post: 01-28-2009, 12:02 AM
