Below is a quote from Involute
"On an unrelated note, when I try to set the spindle speed with M03 S1500, I get an error in Mach3: Error on line 2 - Unspecified failure, and it presents a VB debug screen. I'm pretty sure I have the machine set properly (CNC mode switch is down and the Start button on the keypad has been pressed to remove the Stop annunciator). What might be causing this?"
I have the same problem. Has anyone any clues?
Regards
Chrisjh
