586,065 active members*
4,842 visitors online*
    Retrofitting Hercus VMC 300
    Hello all,
    So I'm looking at installing a new control system for a Hercus VMC 300 that I pulled apart a few months back, It was running on a control system made by a local company but unfortunately they're no longer around.
    It runs on 4 Electro-Craft motors; The three axis are all the same motor type (S240-1A8 REVM, P/N 0240-04-022) And the spindle is a little beefier (S644-3A REV L, P/N 0644-01-034).
    Being quite new to retrofitting a machine from the guts up by myself, I was looking for some advice on control systems compatible with Mach3/4, I'd prefer to keep the original motors and just buy a plug and play kit, But will upgrade the motors if that's easier.
    I am looking at installing limit switches and tool height detectors too, So the ability to interface tools is also a goal of mine.
    Budget is $800-1000
    If you have any questions or would like photos for a better understanding for what I mean I can do that
    P.s. I live in NSW, Australia.
    Kind regards,
    Aaron.
    Jul 2011
    400
    Re: Retrofitting Hercus VMC 300
    I see that this is an older thread and you got no replies. I have a Hercus v300 mill that I did a retrofit on. I used a breakout board from PMDX a 126 model. I also used their speed output board. Going from memory the motor control I used is a KBWT-240. I used gecko drives for the servos. model 320x. I put it all together and got it working. I immediately realized I needed a bigger mill so the hercus has sat idle since. I replaced it with a bigger mill. I'm keeping it around because some day it will have a niche thing it can run when the other mill is busy. If you need any other information let me know.
    I do recommend that you consider something other than mach 3. I just replaced the mach 3 control on the big mill with an acorn and will probably do the same with my other machines.
  1. Hercus VMC300 help
    By Wegs45 in forum Australia, New Zealand Club House
    Last Post: 03-05-2014, 10:13 AM
  2. Hercus lathe
    By Paul in OK in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-21-2009, 02:36 PM
  3. Hercus Computurn
    By Doug Baker in forum Australia, New Zealand Club House
    Last Post: 04-16-2009, 04:45 AM
