586,055 active members*
4,429 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Changing to Ethernet on Haas mini mill and vf2 ?
Results 1 to 7 of 7
    Sep 2012
    Hey guys, we have a haas vf2 and also a mini mill that we have to use floppy disks with. Is there a way to change this on my own and be able to use ethernet from the computer to the machines or does haas have some sort of software block that makes this difficult to do? Tired of floppy drives, they always go bad and i always leave them in the machine when i need them back to the computer and vise versa. Thanks in advance!
    Re: Changing to Ethernet on Haas mini mill and vf2 ?
    Have you considered the USB adapters? I haven't used one but they seem to be pretty popular for the older machines.
    Sep 2012
    Quote Originally Posted by Sam_Beckham View Post
    I didn’t know about these but I’ll have to find that because usb sounds a lot more ideal than floppy disks
    Aug 2009
    1573
    Here is one option. Search for RS232 to IP devices. Price vary widely used and new.
    https://www.ebay.com/itm/TCP-IP-Ethe...gAAOSwSRtdpeVl
    Apr 2016
    4
    Jul 2010
    172
    I installed a floppy to USB emulator in my HAAS Mini Mill and my VF-0E.
    Both were plug and play and are still working perfect today.
    You just have to buy a bunch of smaller USB sticks ($2 each) so you have spares.
    And you have to format them to 750KB blocks.
    I have the program if you need it.
    Floppy to USB Converter, Floppy to USB Emulator, Floppy Disk Drive, Floppy Drive to USB
    Timothy
    Dyna Mechtronics DM4400, Bridgeport Discovery 300, HAAS VF-0E, HAAS VF-2D
    BobCad 16, 20, 24 and now V25
    Feb 2012
    115
    Are you wanting to stay with some type of floppy interface? Or use rs232? One factor is whether or not your machine supports the 115k rs232 rate.
  1. Haas Mini mill
    By LeeWay in forum Haas Mills
    Last Post: 06-12-2017, 09:47 PM
  2. Changing Mini Mill shuttle motor
    By dfearnow in forum Haas Mills
    Last Post: 12-11-2015, 01:15 PM
  3. Mini Mill coolant sitting and changing mix ratio?
    By Terry G in forum Haas Mills
    Last Post: 09-14-2012, 08:42 PM
  4. New Haas Mini Mill
    By Hyrum in forum Haas Mills
    Last Post: 10-10-2010, 03:04 AM
  5. Haas Super Mini-Mill and Haas Trunnion Table
    By Gabe Newell in forum Haas Mills
    Last Post: 06-07-2009, 07:23 PM
