586,103 active members*
3,579 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > Upgrades to my 2018 CNCRP Machine.. Plasma time.
Results 1 to 5 of 5
    Jan 2016
    78
    I've been plotting to add a plasma torch to my CNCRP Pro 60120.. and thought I'd share this design and get feedback from the forum.
    When using the plasma, I will fab up a protective cover for the spindle so it stays clean.
    It's meant to hold a 35mm Hypertherm torch, has a floating head and uses an inductive proximity sensor to detect contact.
    Whilst it looks like the main plate is in 2 pieces, it will actually be milled out of a single piece of 245mm x 150mm 16mm thick 6061 plate
    Brackets out of 12mm plate and the torch plate 6mm. Sourced a 15mm linear guide rail off eBay for $40.
    Looking at a Neuron Lite/Ohmic but the english emails seem to take longer to read !
    Apr 2019
    4
    Re: Upgrades to my 2018 CNCRP Machine.. Plasma time.
    Quote Originally Posted by andrewwong2000 View Post
    I run plasma and spindle on my pro 48x48. Have for about 7 months now. I run the CNC Router Parts setup with dual z-axis. Works REALLY well. I don't cover my spindle, maybe should. It has some spots on it from mild splashes, but that's about it. Nothing I've needed to worry about yet.
    One thing you may run into is interference from the torch on your prox sensors. I've grounded my machine according to Hypertherm's specs. I run the plasma cable as far away from other wires as possible to reduce electrical noise, but I was still getting false triggers of Z and X limit switches. Usually during the piercing when the plasma first fires.
    What I ended up doing is turning off my limit switches. They are still there for homing AND they will still stop me when I am moving the machine manually, but not when the machine is running g-code. I always check my limits before I start anyway.
    Jan 2016
    78
    Seems such a long time ago.. actually managed to make my first cut yesterday !
    It's been a really rewarding journey.. a bit more to go - fabricate the downdraft duct and table slats.
    Feb 2005
    829
    Andrew, holy crap headset warning next time!!! LOL
    Looks like it works great!
    Sep 2005
    1740
    I owned and used a PlasmaCAM for a number of years. The dust is terrible and yes I had a fan and water table but its all over. Very hard on your lungs and wood / metal to not play well in the same shop. I sold the PlasmaCAM years ago… but I still find the dust from time to time.
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
  1. Sheetcam rules, CNCRP Mach3 plasma
    By ebrakespin in forum Avid CNC
    Last Post: 03-25-2019, 07:38 PM
  2. Replies: 0
    Last Post: 03-22-2019, 02:38 PM
  3. Replies: 0
    Last Post: 04-26-2018, 12:00 AM
  4. Ordered the CNCRP Plasma THC setup
    By LeeWay in forum Avid CNC
    Last Post: 10-29-2017, 09:19 PM
  5. Replies: 7
    Last Post: 06-24-2014, 07:25 AM
