586,103 active members*
3,296 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach PCNC 1100 running Mach3 loses Z-axis zero at the start of an operation
    Hi all. I'm relatively new to CNC and the Tormach, but have been (mostly) successfully running g-code for a few months now. My mill has started losing the Z-axis zero after I insert and zero the tool for the first operation of my g-code. I run the code, the machine moves to the tool change position, I put in the tool, name the tool in the Mach3 interface, and set the zero as outlined in section 3 of the Tormach manual. When I start the cycle again, the operation starts about two inches above where I set the zero, but shows zero in the readout.
    I found a thread where someone was having a similar problem here: https://www.cnczone.com/forums/torma...1-tormach.html
    Before upgrading to PathPilot, I wanted to make sure there wasn't crucial maintenance that has been missed that may cause this problem. The machine is not mine, so I'm not sure what maintenance has been done in the past (if any). I would like to check all of the maintenance that I should be doing, then go through the troubleshooting steps, and then move on to updating the controller if necessary. What maintenance should I perform/check, and is my thinking correct regarding the steps I should take to solve this problem?
    Nov 2012
    591
    Re: Tormach PCNC 1100 running Mach3 loses Z-axis zero at the start of an operation
    This is not maintenance based, but it may be tool table offset based. If you set the zero manually after each tool change, then you should make sure the tool table contains "0" for "tool length" for all tool numbers.
    Also: I used to use Mach 3 with a Tormach 1100 before, and I think the PathPilot update is better. It only took a day to get used to the new interface. Not everyone agrees, but there you have it for what it's worth.
    Mar 2013
    344
    G49 before doing new settings.
  1. Tormach PCNC 1100 axis motors and drivers
    By ErnieD in forum Tormach Personal CNC Mill
    Last Post: 04-18-2017, 01:40 PM
  2. Tormach PCNC 1100 V3 losing communication with driver on X axis
    By Ins0mnia in forum Tormach Personal CNC Mill
    Last Post: 12-05-2016, 06:35 PM
  3. Tormach PCNC 1100 with 4th Axis For Sale in Michigan
    By precisepro in forum For Sale Only
    Last Post: 09-15-2015, 04:31 AM
  4. Tormach PCNC 1100 with 4th Axis For Sale in Michigan
    By precisepro in forum Tormach Personal CNC Mill
    Last Post: 09-15-2015, 04:03 AM
  5. Tormach PCNC 1100 4 Axis CNC Mill
    By harry8 in forum For Sale Only
    Last Post: 05-18-2015, 08:01 AM
