586,108 active members*
3,014 visitors online*
Page 3 of 3 123
Results 41 to 48 of 48
  1. #41
    Nov 2015
    260
    Re: TNGv2 for Mac OSX
    I noticed some bug. PlanetCNC does not have a program icon yet. A standard icon for programs will be displayed.
    Another problem I have with the ethernet connection. I tried to connect the MK3 / 9 board via ethernet. But that does not work. The tutorial on Plant-CNC.com does not help.
    What needs to be done in the network settings in OS X?
    edit:
    OK. I got it, I'm not sure but I think it was due to the wrong hardware configuration in the network settings under more options. There I have everything now set to Automatic.
  2. #42
    Mar 2017
    1312
    I've added icon. It will be in next release.
    I have no troubles using network controllers. It is probably your network settings.
  3. #43
    Nov 2015
    260
    Another problem is that the fullscreen mode does not work..
  4. #44
    Mar 2017
    1312
    Main menu and dock remain visible if they are not set to be hidden in system preferences. This is by design.
  5. #45
    Nov 2015
    260
    I would prefer if the dock and the menu bar are hidden.
  6. #46
    Nov 2015
    260
    For insataltion this will work too.
    Code:
    sudo xattr -d com.apple.quarantine /Applications/FreeCAD.app
    The PlanerCNC app have to be in Applications.
  7. #47
    Nov 2015
    260
    Sorry, i dump, i don't chande the App name. next Trty
    For insataltion this can work too.
    to remove the quarantine, only for the named program / app
    Code:
    sudo xattr -d com.apple.quarantine /Applications/PlanetCNC/PlanetCNCMacOS.app
    Code:
    sudo chmod -R 777 /Applications/PlanetCNC/PlanetCNC/
  8. #48
    Nov 2019
    41
    Any Mac users have issues when start PlanetCNC getting a dialogue stating "There is a problem accessing settings file." . I followed the instructions for installing found at https://www.cnczone.com/forums/attac...0&d=1574429542 (and the Readme.txt file with the installer). I have done the chmod file permissions for the entire folder. I have tried placing the PlanetCNC folder in the applications folder as well as the Documents folder. As a result of this issue PlanetCNC will not save any settings, so it is non-functional at this point.
    Any ideas on what could be causing this?
Page 3 of 3 123
  1. [TNGv2] - Wireless handwheel (MPG pendant)
    By PlanetCNC in forum PlanetCNC
    Last Post: 02-01-2022, 06:41 PM
  2. [TNGv2] - 2019-10-28
    Last Post: 10-28-2019, 04:52 PM
  3. [TNGv2 - API]
    Last Post: 10-27-2019, 11:23 PM
