586,051 active members*
3,802 visitors online*
Page 1 of 3 123
Results 1 to 20 of 48
    Nov 2015
    260
    TNGv2 for Mac OSX
    Hi. I am very pleased about the support of MAC OSX. Unfortunately the software will not start under OSX 10.15 (Catalina). She ends immediately.
    Greetings Daniel
    Nov 2015
    260
    Re: TNGv2 for Mac OSX
    OSX Mojave 10.13.4 (Mojave) don't run too.
    Mar 2017
    1312
    I tested this on Sierra, High Sierra and Mojave. I see no reason not to work on Catalina.
    I created subfolder named "PlanetCNC" in "Documents" folder and I copied files PlanetCNCMacOS.app, libPlanetCNCLibMacOS.dylib and libPlanetCNCCoreMacOS.dylib. TNG is started by clicking on PlanetCNCMacOS.app.
    I'm not Mac user and I know very little about Macs but this worked on machines where I tested it.
    Nov 2015
    260
    Catalina have no longer support for 32 Bit Apps.
    Mar 2017
    1312
    TNG for MacOS is 64bit app.
    Nov 2015
    260
    Has anyone except PlanetCNC successfully started the software?
    Nov 2015
    260
    Does the MK board need to be connected?
    Mar 2017
    1312
    You probably don't allow applications from other sources to run on your Mac. You need to give this permission:
    1. open terminal and type:
    sudo spctl --master-disable
    2. then open "System Preferences/Security & Privacy" and set "Allow apps..." to "Anywhere". See screenshot.
    Nov 2015
    260
    No, that's not the problem. I have enabled the release of the program via the Control Panel, of course.
    Mar 2017
    1312
    Do you get any error, log or report?
    Nov 2015
    260
    No, No report
    Mar 2017
    1312
    Please execute this in terminal:
    sysctl machdep.cpu.features
    and send me results
    Nov 2015
    260
    I have now installed High Sierra. But even with this version it does not start. But here is a log:
    Process: PlanetCNCMacOS.app [1011]
    Path: /Volumes/VOLUME/*/PlanetCNCMacOS.app
    Identifier: PlanetCNCMacOS.app
    Version: 0
    Code Type: X86-64 (Native)
    Parent Process: ??? [1]
    Responsible: PlanetCNCMacOS.app [1011]
    User ID: 501
    Date/Time: 2019-11-01 10:14:40.027 -0700
    OS Version: Mac OS X 10.13.6 (17G66)
    Report Version: 12
    Anonymous UUID: D3C25F72-B71C-DCBB-495D-684339CB0175
    Time Awake Since Boot: 1600 seconds
    System Integrity Protection: enabled
    Notes: Translocated Process
    Crashed Thread: 0
    Exception Type: EXC_CRASH (SIGABRT)
    Exception Codes: 0x0000000000000000, 0x0000000000000000
    Exception Note: EXC_CORPSE_NOTIFY
    Termination Reason: DYLD, [0x1] Library missing
    Application Specific Information:
    dyld: launch, loading dependent libraries
    Dyld Error Message:
    Library not loaded: @loader_path/libPlanetCNCCoreMacOS.dylib
    Referenced from: /Volumes/VOLUME/*/PlanetCNCMacOS.app
    Reason: image not found
    Binary Images:
    0x104f67000 - 0x104f67ff3 +PlanetCNCMacOS.app (0) <D84D20C3-EEBE-3DD8-BFE8-35691E866C6C> /var/folders/*/PlanetCNCMacOS.app
    0x10fa17000 - 0x10fa61acf dyld (551.4) <8A72DE9C-A136-3506-AA02-4BA2B82DCAF3> /usr/lib/dyld
    Model: iMac10,1, BootROM IM101.00D0.B00, 2 processors, Intel Core 2 Duo, 3,06 GHz, 12 GB, SMC 1.53f13
    Graphics: ATI Radeon HD 4670, ATI Radeon HD 4670, PCIe
    Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1067 MHz, 0x80CE, 0x4D34373142353637334548312D4346382020
    Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1067 MHz, 0x80CE, 0x4D34373142353637334548312D4346382020
    Memory Module: BANK 0/DIMM1, 4 GB, DDR3, 1067 MHz, 0x0198, 0x393930353432382D3032302E4130304C4620
    Memory Module: BANK 1/DIMM1, 4 GB, DDR3, 1067 MHz, 0x02FE, 0x45424A3431554638424153302D41452D4620
    AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x8F), Atheros 9280: 4.0.74.0-P2P
    Bluetooth: Version 6.0.7f10, 3 services, 27 devices, 1 incoming serial ports
    Network Service: Wi-Fi, AirPort, en1
    Serial ATA Device: WDC WD1001FALS-40U9B0, 1 TB
    Serial ATA Device: HL-DT-ST DVDRW GA11N
    USB Device: USB Bus
    USB Device: IR Receiver
    USB Device: USB Optical Mouse
    USB Device: USB Bus
    USB Device: BRCM2046 Hub
    USB Device: Bluetooth USB Host Controller
    USB Device: USB 2.0 Bus
    USB Device: Built-in iSight
    USB Device: Internal Memory Card Reader
    Thunderbolt Bus:
    Nov 2015
    260
    next i will test El Capitano
    Mar 2017
    1312
    Is it possible that this is just permission issue? I noticed that I used "chmod -R 777" on my folder.
    Nov 2015
    260
    ast login: Fri Nov 1 18:27:07 on ttys000
    The default interactive shell is now zsh.
    To update your account to use zsh, please run `chsh -s /bin/zsh`.
    For more details, please visit https://support.apple.com/kb/HT208050.
    COMD-2:~ admin$ sysctl machdep.cpu.features
    Mar 2017
    1312
    What? You should get something like this:
    machdep.cpu.features: FPU VME DE PSE TSC MSR PAE MCE CX8 APIC SEP MTRR PGE MCA CMOV PAT PSE36 CLFSH DS MMX FXSR SSE SSE2 SS HTT SSE3 PCLMULQDQ MON SSSE3 FMA CX16 SSE4.1 SSE4.2 x2APIC MOVBE POPCNT AES VMM PCID XSAVE OSXSAVE TSCTMR AVX1.0 RDRAND F16C
    Nov 2015
    260
    Quote Originally Posted by tantemay View Post
    Oh, I can not downgrade. But new from Catalina. Here I can start it now. But the Ortner must be in the program folder, sunstay it does not work. However, this does not work for High Sierra
    Nov 2015
    260
    Oh well, now it does not work again, so it is not synonymous s.der file location.
    Nov 2015
    260
    Alo heavy birth. I now had to put the app in the app folder and start, then the files. And then let the program / App start ..
    And that's how it works with High Sierra
Page 1 of 3 123
  1. [TNGv2] - Wireless handwheel (MPG pendant)
    By PlanetCNC in forum PlanetCNC
    Last Post: 02-01-2022, 06:41 PM
  2. [TNGv2] - 2019-10-28
    Last Post: 10-28-2019, 04:52 PM
  3. [TNGv2 - API]
    Last Post: 10-27-2019, 11:23 PM
