586,100 active members*
2,722 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Import SVG/DXF/Image do nothing (do not work)
Results 1 to 3 of 3
    Aug 2023
    4
    I am using PlanetCNC for a while now and I am pretty satisfied. Until now I generated the g-code in another CAM Software and used PlanetCNC only for machining.
    Now I wanted to use the import functions for SVG, DXF or Image - but they simply dont work.
    I am doing the following:
    File -> Import SVG -> Select SVG (from local Filesystem) -> do not change any Settings -> OK.
    There is no Gcode generated, nothing happens.
    I tried changing different Settings on Import - no Luck.
    I tried different Imports (DXF, Image) - the same.
    I tried a SVG from a PlanetCNC Howto to be sure the SVG is OK. Same.
    No errors in the Log.
    Attached a few screenshots
    I am using PlanetCNC 2023-06-20 on Ubuntu 23.04. Does anyone know this issue?
    best regards,
    Florian
    Aug 2023
    4
    Re: Import SVG/DXF/Image do nothing (do not work)
    I've found it out. The problem is related to the "new" X Server "Wayland". It is used by default since Ubuntu 21.04 in 2021. When using the old XOrg everything works fine (there is a little gear Symbol on the login screen where you can switch the X Server if somebody has the same problem, see screenshot)
    At some day in the future the old XOrg will not be supported anymore - so it would be cool if someone from the PlanetCNC Team is addressing this issue.
    Best regards,
    Flo
    Mar 2017
    1312
    I doublechecked with Ubuntu 22.04.3 LTS and there are no issues.
    Dxf import also works without any issues. Your problem is elsewhere.
  1. Replies: 0
    Last Post: 03-22-2021, 09:51 PM
  2. 3 in 1 highchair dxf svg or eps
    By paulisa2 in forum USA Club House
    Last Post: 09-11-2017, 06:54 AM
  3. Invert STL/SVG or DXF file
    By nambass in forum Uncategorised CAM Discussion
    Last Post: 10-08-2013, 12:35 PM
  4. Inkscape .SVG to SolidWorks .DXF
    By BasuraBlanco in forum Solidworks
    Last Post: 08-07-2012, 04:21 PM
  5. mach 2 import image
    By gilligan in forum Machine Created Art
    Last Post: 11-23-2006, 12:22 AM
