586,103 active members*
3,355 visitors online*
    Oct 2019
    Bridgeport Interact 1 TNC145
    Hello fellow CNC geeks
    I have a problem with my interact series 1 mill and need to consult you guys on what you think is the cause and hopefully solution to my issue. Hope someone can help.
    The machine recently lost itself and threw up an error message: "Gross Positioning Error B"
    This happens on both X and Y axis.
    I noticed sometimes the axis jumps slightly when moving the machine manually.
    The feed rate override is also not working and seems to be stuck on full.
    Can anyone steer me in the right direction on this? Any help would be much appreciated. Thanks in advance.
    Danny.
    May 2016
    526
    Re: Bridgeport Interact 1 TNC145
    Check your motor brushes
    1121
    check your tach trailing error adjustment
    has this machine run before
    Also the override pots die, but even if that is so, it is not your problem
  1. Bridgeport interact TNC145 Z feed constantly on
    By Mike Woo in forum Bridgeport / Hardinge Mills
    Last Post: 01-11-2017, 01:16 AM
  2. Bridgeport S1 interact with TNC145 servo fault in one direction on X
    By alexyates in forum Bridgeport / Hardinge Mills
    Last Post: 12-16-2015, 11:15 AM
  3. Bridgeport Interact Series 1, TNC145
    By jack-pat in forum Bridgeport / Hardinge Mills
    Last Post: 02-16-2015, 01:17 PM
  4. Bridgeport interact with Heidenhain TNC145
    By johnn1 in forum Bridgeport / Hardinge Mills
    Last Post: 02-14-2012, 10:05 PM
  5. interact tnc145
    By bigbaz in forum Bridgeport / Hardinge Mills
    Last Post: 02-02-2008, 05:19 PM
