586,058 active members*
4,658 visitors online*
Page 2 of 3 123
Results 21 to 40 of 41
  1. #21
    Oct 2005
    45
    Re: PM-932m CNC Conversion
    After some further discussion with JT @ Mesa US I've decided to go with the Mesa 7i76E as originally recommended (good call!).
  2. #22
    Sep 2006
    509
    Glad you talked to one of the 2 vendors - I think you'll be very happy with that setup.
    As far as the PC goes - you may want to have it closer to the screen depending on where the electronics box ends up. Otherwise you have to run multiple long cables to your screen and other input devices (mouse & keyboard, pendant, etc). If you have the pc near the screen its just the cat5e cable back to the electronics box (and maybe the AC power for it). Also makes it easier to plug in USB sticks unless you plan that out in advance too.
  3. #23
    Oct 2005
    45
    Quote Originally Posted by ninefinger View Post
    I will probably have the PC initially set up on its own cart, with the connection to the CNC control box being via the ethernet cable.
    I have an older Asrock C2750D4I Mini-ITX motherboard that I'm thinking of using as the PC's guts.
    Maybe with a Mini-ITX case that can be VESA mounted on a monitor arm...
    The motherboard is fanless, and has the benefit of having 2 x LAN ports - one for internet access, and the other for the CNC control.
  4. #24
    Oct 2005
    45
    I also have one of these Supermicro X10SDV-TLN4F Mini-ITX boards that I modified with a copper finned heatsink...
    But this board is massive overkill...
    The other C2750 board may be fine, but I'm also concerned about the lack of USB ports (3 max), and I'd rather not have to do USB hubs...
    Maybe one of those J1900-style ultra compact PCs?
  5. #25
    Oct 2005
    45
    Kind of looking at this J1900-based SFF PC, Qotom Q190S.
    Benefits:
    • Fanless
    • VESA Mount
    • 2 x LAN Ports - 1 for Internet, 1 for Mesa
    • 3 x USB 2.0 Ports
    • 1 x USB 3.0 Port
    • HDMI and VGA
    • RS-232 Serial
    • Quad-Core CPU, 2.0/2.4 Ghz, 8GB RAM, 64GB disk.
    $188 + $30 shipping from Qotom.
  6. #26
    Oct 2005
    45
    I've figured out the size I will use for linear rails - 25mm Hiwin HG series, as they're easily available.
    A quick price check of Hiwin HG series, 2 sets of 25mm rails with 2 blocks per rail, from MotionConstrained.com:
    • X Axis HGH25CAZAC 520mm: $291
    • Y Axis HGH25CAZAC 820mm: $353
    • Z Axis HGH25CAZAC 700mm: $328
    I've also determined how to mount the rails to the Z axis:
    Precision ground steel bars from McMaster (thickness ground to +/- 0.025mm), one 3mm x 20mm bar as a datum reference, and two 10mm x 25mm bars as support for the rails.
    It's a combination of ideas I've borrowed from Youtube users CNC4XR7 and MetalMusings.
    CNC4XR7 had the idea for the datum bar with a PM-727, and MetalMusings had the idea for the double-stacked support bars.
    Attachment 431120
  7. #27
    Oct 2005
    45
    Hiwin HG vs RG Series
    I was able to get a price from MotionConstrained.com for a full set of Hiwin RG-series rails in the 20mm size for about $1100, a little bit more than the cost for the HG series.
    And still half the price of the RG series from the other vendor.
    So, let's take a look at the differences between the HG and RG rails.
    HG 25mm on the left, RG 25mm on the right.
    The HG series have fewer mounting holes, spaced further apart - allowing for some inaccuracies in tolerance when installing.
    The RG series have twice the number of mounting holes, and require a smaller tolerance / greater accuracy when installing.
    The RG series are much stiffer, with a higher dynamic load range.
    Hiwin HG description:
    The HG series linear guideways are designed with load capacity and rigidity higher than other similar products with circular-arc groove and structure optimization. It features equal load ratings in the radial, reverse radial and lateral directions, and self-aligning to absorb installation-error. Thus, the HG series linear guideways can achieve a long life with high speed, high accuracy and smooth linear motion.
    Hiwin RG description:
    The RG series features a roller as the rolling element instead of steel balls. The RG series is designed with a 45-degree angle of contact. Elastic deformation of the linear contact surface, during loading, is greatly reduced thereby offering greater rigidity and higher load capacities in all 4 load directions. The RG series linear guideway offers high performance for high-precision manufacturing and can achieve a longer service life than traditional ball bearing linear guideways.
    So with all else being equal, I'd probably go for the RG series in 25mm size if I can arrange it.
    Attachment 431170
    Attachment 431172
  8. #28
    Oct 2005
    45
    Hiwin RG Series rails on the X and Y axis.
    The Rails on the X axis (the table) have datum bar spacers that are offset - the fronts (right side) are 20mm, while the rears (left side) are 15mm.
    This is necessary because the dovetails are asymmetric, and there's less room on the back of the table.
    Attachment 431200
    The Y axis rails are mounted similar, but these dovetails are symmetric so the spacers are the same.
    Attachment 431202
    Attachment 431204
    The mounting arrangement of a thin datum bar and two 10mm riser bars leaves a gap in between the steel bars and the edge of the dovetail.
    I think I will probably fill that in with epoxy sand/gravel for some stability.
  9. #29
    Oct 2005
    45
    The steel panel for the electronics box arrived.
    It's thicker and heavier than I expected.
    18" x 18"
    Sent from my Pixel 3 XL using Tapatalk
  10. #30
    Oct 2005
    45
    This enclosure box is bigger than I was expecting!
    It has two pre-drilled holes on the cover panel.
  11. #31
    Oct 2005
    45
    Re-working the design to use RG 25mm rails, and also 25mm ballscrews.
    25mm ballscrews require a larger MBA20-F motor mount, and a special FKA20 bearing mount on the front, standard BF20 floating end.
    The motor mount is bolted to a 6" cast iron angle plate that's had one side cut down and will bolt on to the front of the base casting.
    The plate on top of the Y-axis blocks is 35mm thick, with a notch cut in on one side for clearing the motor mount, and with clearance channels cut underneath for the OFU2505 double-ballnut.
    The plate should be relatively easy to machine manually with just endmills and boring bars.
    Attachment 431346
    Attachment 431348
Name:	PM-932m Linear Rails v6 - Base Back.png
Name:	PM-932m Linear Rails v6 - Base Front.png
  12. #32
    Mar 2004
    1306
    I once went down this rabbit hole as well. At the end of the day, what is the point of buying the RF-45 clone? The only parts you end up keeping are the four main castings, and they are all heavily modified. You may as well put the money from the RF-45 clone into a paying someone else to do the machining of home built versions of these four structural components. YOu obviously have the design skills to do this. Whether you do the frame in heavy square section steel like a Fadal, or epoxy granite is a personal taste.
    I ended up buying an existing CNC machine (Maho) with a dead controller, and retrofitting that.
    For example, for the price of a RF-45, you could get this german guys MAHO 400E for €1100 and pay for shipment to the states, have awesome ballscrews, hydraulic tool release, way oiler, a back gear spindle for torque, much better iron, and a fourth axis.
    Peters CNCECKE
    Mark
    Regards,
    Mark
  13. #33
    Oct 2005
    45
    Something like that would be cool, I admit...
    But I think I would have trouble getting it through the doorway into the space in my basement, even if I was able to disassemble it.
  14. #34
    Mar 2004
    1306
    Maybe a steel frame like a mini Fadal? Laser cut steel is very cheap these days.
    Regards,
    Mark
  15. #35
    Oct 2005
    45
    Possibly.
    There is a video of a guy on YouTube that made his CNC mill out of epoxy granite castings, and even has the BT30 belt-driven spindle.
    Here it is:
    https://youtu.be/rbqY8Mcbh0Q
    So, I might go down that route for a 2nd mill.
    Or go down the route of VMC style with vertical aluminum/steel plates as you mentioned.
    At this point this is all a thought experiment, and I may just use the PM-932 / RF-45 as is with the simplest conversion I can come up with, just to get started.
  16. #36
    Sep 2006
    509
    While I appreciate a robust build I tend to also dislike the "bigger is always better" approach as it is wasteful and not necessarily true.
    IMHO the 25mm ballscrews are way too big for this machines weight and power handling capacity. Using the Misumi calculation software its seems that even 15mm are suitable, and I didn't check smaller than that.
    I also checked against my own spreadsheet I used 15 years ago when building my machine and 16mm ballscrews are ok in it too.
    The most heavily loaded axis is Z and 20mm is fine for it, so you could just standardize at that size.
    You don't really benefit from going larger and just create new issues with spacing and fitment. Also for the Y axis and maybe Z axis you should do the calculations but you can likely run fixed at the one end and free at the other end for simplicity, you only really need to support the far end for long screws that may whip if spun too fast (i.e. for X axis)
  17. #37
    Oct 2005
    45
    Thanks for that info.
    Do you have a link for the Misumi / Mitsumi calculation software?
  18. #38
    Sep 2006
    509
    https://us.misumi-ec.com/maker/misum.../choice06.html
    There are others too that are online - you need to know / assume a bunch of stuff (Mass, acceleration, max velocity, lengths) but shouldn't be too hard.
  19. #39
    Apr 2020
    5
    Hi gmoschini,
    Have you purchased your BT30 cartridge spindle yet?
    I want to upgrade my Sherline ER16 collet spindle to something a little stronger and more convenient. I have been looking at these cheap Chinese Spindles but I have not really found anyone who has given them good feedback.
    Definitely interested to hear your experiences.
  20. #40
    Oct 2005
    45
    I'm still a long way off from purchasing a BT30 spindle cartridge, unfortunately.
    I have the mill and I have my DMM servos, but I haven't had the opportunity to get them under power yet.
    Next step is power for the mill, then seeing about some ballscrews to get the CNC conversion started.
Page 2 of 3 123
  1. CNC Conversion
    By cookie28b in forum Australia, New Zealand Club House
    Last Post: 11-02-2014, 02:03 AM
  2. CNC conversion possible?
    By Jules_B in forum Uncategorised MetalWorking Machines
    Last Post: 06-19-2011, 10:46 AM
  3. conversion of .stp to 3d pdf
    By prozium in forum 3D Printing / Scanning Software and Hardware
    Last Post: 06-18-2011, 01:02 PM
  4. My X3 CNC Conversion
    By cadmonkey in forum Benchtop Machines
    Last Post: 07-03-2009, 04:30 PM
  5. servo conversion vs stepper conversion
    By contractdesign in forum Bridgeport / Hardinge Mills
    Last Post: 07-26-2008, 08:54 PM
